05-05-2011, 16:09 | #1 (permalink) |
Insane Poster Join Date: Mar 2011
Member: 1535487 Status: Offline Thanks Meter: 8 | St_ear_data_loop test fatal? I FLASHED WITH LATEST VERSION BUT SAME SELFTEST RESULT IS BELOW (HERE) WHAT IS THE SOLUTION OF THIS ERROR PLZ EXPERT HELP ME HERE IS THE PHONE LOGS ATF Software Version v7.40 ATF Box FBUS Flash Started... Number of Image Files: 1 MCU: V ICPR71_09w47.5 24-05-10 RM-343 (c) Nokia IMEI: 357976032516627 Model : Nokia E66 Product Serial Number: SDJ110805 Product Code : 0566487 Basic Production Code: 0566001 Default SN Type : 0 PPM Version : V ICPR71_09w47.5 24-05-10 RM-343 (c) Nokia HW Version : 0703 RFIC Version : 17141715 DSP Version : ICPR71_09w40 AHNE Version : 11 APE SW Core Version : 500.21.009 APE Variant Version : 500.21.009500.21.009_v10 APE Test Version : RM343ENO74110842.a26 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL1/PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE PM 120 Found... PM 308 Found... SimLock Certificate Saved to : C:\AdvanceBox Turbo Flasher\Nokia\Backup\357976032516627\SL2_certifica te_V ICPR71_09w47.5 24-05-10 RM-343 (c) Nokia_357976032516627_Not Locked_73704.pm Changing MODE : FLASH AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01031103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1A300116 ID DWORD 1 : 1E408B52 ID DWORD 2 : 79B39D2D ID DWORD 3 : 0F818237 ID DWORD 4 : 08AA4A5F 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 8F SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 010.050.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 Checksum : 25 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g Algorithm File - Version 010.050.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93 START READING RPL DATA Reading : NPC (CMT) OK Reading : VARIANT (CMT) VARIANT : Empty Reading : CCC (CMT) OK Reading : HWC (CMT) OK Reading : R&D (CMT) OK FINISHED READING RPL DATA RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\357976032516627\3579760325166 27_73712.rpl FlashInfo.RestartMode : 2 Processing Image File : C:\Documents and Settings\Administrator\Desktop\E66_blank_504KB_pmm _10.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 4 Entry Point: 0x00EB Page Format : -1 MAX PAGE : 0x00020000 CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 4 Entry Point: 0x00EB Page Format : -1 MAX PAGE : 0x00020000 Changing MODE : FLASH VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01031103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1A300116 ID DWORD 1 : 1E408B52 ID DWORD 2 : 79B39D2D ID DWORD 3 : 0F818237 ID DWORD 4 : 08AA4A5F 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 8F SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 010.050.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 Checksum : 25 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g Algorithm File - Version 010.050.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE No partition info.... NO ERASE DATA FOR THIS IMAGE... Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz (AUTO) Processing : E66_blank_504KB_pmm_10.fpsx Total blocks to write : 4 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:00 Total Flash Write Time (Flashing Only) : 00:00:00 Total Flashing Time (Booting + Erase + Flashing) : 00:00:03 FlashInfo.RestartMode : 2 Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s MCU: V ICPR71_09w47.5 24-05-10 RM-343 (c) Nokia IMEI: 357976032516627 Model : Nokia E66 Product Serial Number: SDJ110805 Product Code : 0566487 Basic Production Code: 0566001 Default SN Type : 0 PPM Version : V ICPR71_09w47.5 24-05-10 RM-343 (c) Nokia HW Version : 0703 RFIC Version : 17141715 DSP Version : ICPR71_09w40 AHNE Version : 11 APE SW Core Version : 500.21.009 APE Variant Version : 500.21.009500.21.009_v10 APE Test Version : RM343ENO74110842.a26 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL1/PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK SELFT TEST Start.... SELFT TEST Done.... MCU: V ICPR71_09w47.5 24-05-10 RM-343 (c) Nokia IMEI: 357976032516627 Model : Nokia E66 Product Serial Number: SDJ110805 Product Code : 0566487 Basic Production Code: 0566001 Default SN Type : 0 PPM Version : V ICPR71_09w47.5 24-05-10 RM-343 (c) Nokia HW Version : 0703 RFIC Version : 17141715 DSP Version : ICPR71_09w40 AHNE Version : 11 APE SW Core Version : 500.21.009 APE Variant Version : 500.21.009500.21.009_v10 APE Test Version : RM343ENO74110842.a26 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL1/PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE MCU: V ICPR71_09w47.5 24-05-10 RM-343 (c) Nokia IMEI: 357976032516627 Model : Nokia E66 Product Serial Number: SDJ110805 Product Code : 0566487 Basic Production Code: 0566001 Default SN Type : 0 PPM Version : V ICPR71_09w47.5 24-05-10 RM-343 (c) Nokia HW Version : 0703 RFIC Version : 17141715 DSP Version : ICPR71_09w40 AHNE Version : 11 APE SW Core Version : 500.21.009 APE Variant Version : 500.21.009500.21.009_v10 APE Test Version : RM343ENO74110842.a26 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL1/PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE THAKSS IN ADVANCE |
My 5130 shows 25 mA in stdby, another 4mA in Netmonitor test 23 | mr_x4you | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-23-2001 11:07 |
only Test | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-29-2000 21:43 |
Has someome tested this software Nokia New Series Tool? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 09-20-2000 16:39 |
I have that soft if smb need ask for testing.. | Nec | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-01-2000 23:47 |
Help my about 2110 (Shelf-test-failed) | jonwillow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-30-1999 20:06 |
