Old 09-07-2006, 10:29   #1 (permalink)
celluniversal's Avatar
Member: 139388
Thanks Meter: 98
6020 strange problem
Nokia 6020 working fine for some minutes and suddenly goes to white screen and getting off and sometimes phone restarting
I flashed the phone but no use same status
SAME PROBLEM I AM FACING IN THE 6230i ALSO
Old 09-07-2006, 11:23   #2 (permalink)
Member: 95807
Thanks Meter: 2
just flash with same ver of mcu ppm it will be ok
Old 09-07-2006, 13:23   #3 (permalink)
Member: 139388
Thanks Meter: 98
Already done 2,3 times
Old 09-08-2006, 08:48   #4 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
Erase and flash it MCU,PPM &CNT and write PM file.Some time by flashing CNT can solve your problem.
Old 09-08-2006, 10:10   #5 (permalink)
Member: 139388
Thanks Meter: 98
i already done that too
Old 09-08-2006, 11:19   #6 (permalink)
Member: 149576
Thanks Meter: 57
try reheat the flash memory
Old 09-08-2006, 12:27   #7 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
this is 100% cnt fault..........
flash with the newer version........... mcu+ppm+cnt......... write pm....... ui settings............done....
Old 12-30-2007, 18:44   #8 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
i also have one 6020 in which the same problem exists...
is there any exact solution of this problem ....
please reply..
Old 12-30-2007, 19:04   #9 (permalink)
Member: 217853
Thanks Meter: 13
do rehot the upp and check whether prob solved or not if not then change upp problem getz solved. post reply
Old 12-30-2007, 20:31   #10 (permalink)
Member: 480959
Thanks Meter: 49
All Are useless Just Reboil Flash IC ur set will Be ok Becouse i have the same problem with 3220 i had done all but same problem but after reboiling the flash the problem solbed.
nokia 6020 strange problem aplus_mobile Nokia Digital Core Technology 4 ( DCT-4 ) 7 04-22-2013 17:22
n95 (rm-159) strang problem Tayyab_raja777 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 04-21-2010 09:01
I8510 strang problem naslejavan QUALCOMM Models (3G) 4 03-30-2010 09:32
n95 (rm-159) strang problem Tayyab_raja777 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-29-2010 14:45
Strange Problem for NOKIA 6020 sujithsidhardhan Nokia Digital Core Technology 4 ( DCT-4 ) 2 11-13-2006 14:56
Page generated in 0.17045 seconds with 9 queries
