6030 flashing problem Content extract fail, continue anyway ... FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFFFlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D8DACC:9C6BDA60Area [01000000-0101FFFF] erased in 0.656 s Area [01020000-017BFFFF] erased in 37.657 s Area [01F20000-01FDFFFF] erased in 4.031 s Flash programming ... Programming completed in 1 min 35.828 s File Processed in 2 min 29.157 s Processing CNT file: rm74__5.40.image_g [DCT4,DCT4 ALGORITHM] page size: 64 K size: 768.68 KBSupported Ids: 1131, 1130, 2140, 2141, 2142, 2143, 2031 ASIC ID: 0x2031 [UPP_4M ver: 3]SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFFFlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D8DACC:0BDFDA6AArea [01C00000-01F1FFFF] erased in 15.438 sConverting UCP blocks to 128 K. Flash programming ... Programming completed in 10.672 s Content extract fail, continue anyway ... File Processed in 1 min 50.781 s Processing PPM file: rm74__5.40g [DCT4,DCT4 ALGORITHM] size: 1.21 MBSupported Ids: 1131, 1130, 2140, 2141, 2142, 2143, 2031 ASIC ID: 0x2031 [UPP_4M ver: 3]SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFFFlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D8DACC:2984DA60Area [017C0000-01BFFFFF] erased in 21.328 s Flash programming ... Programming completed in 17.469 s File Processed in 52.125 sFlashing completed in 5 min 45.328 s Phone not responding ! |
try to another flashing cable. |
i think cable is good i am try any other phone will be work fine |
rehot cpu and flashing ............your set will ok |
your set not gone to local mode its hard wear problem |
1st Boot Ok, DCT4, UPP: 2031 Fl0: 0x01000000-0x01FFFFFF,00012C7E,Amd 29NS128N Algorithm: u_amd.fia, Ver: 4.57.0 Algorithm Ok, MSID: 8441BCF027759629B0582B5C95 Decoded MSID: 8BA1BAE9-00D8DACC-A8000000 Encoded FAID: C274AD31-4DEC4C40-9C5E5273 Area1: 0x01000000-0x0101FFFF Erased, Time: 00:00 Area2: 0x01020000-0x017BFFFF Erased, Time: 00:37 Area3: 0x01F20000-0x01FDFFFF Erased, Time: 00:03 MCU Flashing Completed, Time: 01:04 Chip SECTOR_SIZE: 128k, File FAT_SECTOR_SIZE: 64k Warning, Must be Used 128Kb Sector_Size CNT File CONVERSION ERROR: Not Nokia Image File Failed to Convert CNT File File: rm74__5.40.image_e_128 not Found Error in CNT File Conversion or Selection Process Failed, Repowering Mobile |
yes its hardwear problem i am make rehote upp then flash will be ok |
send me log with ufs and mxkey thank u |
