Old 03-05-2008, 19:16   #1 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
6030 fm not working..........
hello sir i have nokia 6030 it's radio not working.when try to select radio it not selecting i flash with jaf with ver 5.40 & change bottom conector but problem is still same i also heat radio ic but no result plesae tell me it,s soft or hardwere problem with solution......
The Following User Says Thank You to rk19801 For This Useful Post:
Old 03-05-2008, 22:41   #2 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
just make ui settings with ufs.........................
100% tested.
..::HUM::..
Old 03-06-2008, 04:40   #3 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
thanks for reply sir but stii same condition.....
Old 03-06-2008, 04:47   #4 (permalink)
Registered User
Member: 171336
Thanks Meter: 61
Cool
downgrade the phone i have the same problum now is working (using UFS)
Old 03-06-2008, 05:11   #5 (permalink)
Member: 170684
Thanks Meter: 19
Cool 100% working
its radio ic complent, if you heat it won't work may be your mobile water log change the radio ic 100% working tested.
The Following User Says Thank You to harisha g h For This Useful Post:
nokia 6030 ringer not working i will change ringer ic but not work please post image prakash40 Nokia Hardware & Hardware Repair 3 09-19-2009 13:02
Nokia 6030 Fm Not Working venusmobilecare Nokia Hardware & Hardware Repair 2 09-04-2007 07:28
6030 fm not working venusmobilecare Nokia Hardware & Hardware Repair 0 09-04-2007 06:44
Nokia 6030 Fm Not Working venusmobilecare Nokia Hardware & Hardware Repair 0 09-03-2007 12:46
6030 FM not working jackle123 Nokia Digital Core Technology 4 ( DCT-4 ) 0 12-02-2005 19:47
Page generated in 0.19888 seconds with 9 queries
