Old 07-03-2007, 16:49   #1 (permalink)
Member: 415645
Thanks Meter: 15
Arrow 6030 lcd is blue, help
pls help me urgently. nokia 6030 lcd is blue after fell down on the ground. all the parts is ok and lcd is too ok . i have also change the lcd but the problem is same. pls help me
Old 07-03-2007, 18:23   #2 (permalink)
.:KHALIFA:.'s Avatar
Member: 275631
Thanks Meter: 408
reball cpu.......
change cpu......
akk b fine
The Following User Says Thank You to .:KHALIFA:. For This Useful Post:
Old 07-03-2007, 18:35   #3 (permalink)
Member: 415645
Thanks Meter: 15
any other solutin (reboling cpu)
Old 07-04-2007, 04:05   #4 (permalink)
..:MumbaiGsm:..'s Avatar
Member: 205738
Thanks Meter: 129
change display connector.....try to check track of pin no.2 of it
The Following User Says Thank You to ..:MumbaiGsm:.. For This Useful Post:
Old 07-04-2007, 04:35   #5 (permalink)
Bagscom's Avatar
Member: 319976
Thanks Meter: 14
try to change the display..
Old 07-04-2007, 04:36   #6 (permalink)
Bagscom's Avatar
Member: 319976
Thanks Meter: 14
try to change the display connector...
The Following User Says Thank You to Bagscom For This Useful Post:
Old 07-05-2007, 16:08   #7 (permalink)
Member: 415645
Thanks Meter: 15
thanks to all member for reply
Old 07-05-2007, 16:25   #8 (permalink)
riadhset's Avatar
Member: 39239
Thanks Meter: 97
change lcd good luck
The Following User Says Thank You to riadhset For This Useful Post:
Old 07-05-2007, 17:39   #9 (permalink)
bpcentergtk's Avatar
Member: 311436
Thanks Meter: 38
first of all put some liquid paste on lcd connector and resold with iron if not then change connector if not replace with new lcd if not then flash the phone post result
The Following User Says Thank You to bpcentergtk For This Useful Post:
Old 07-05-2007, 18:08   #10 (permalink)
HAROON's's Avatar
Member: 100592
Sonork: 1578498
Thanks Meter: 245
here it is
best of luck
Best Regards
GSMCrazy1
The Following User Says Thank You to HAROON's For This Useful Post:
Old 07-06-2007, 17:16   #11 (permalink)
Member: 415645
Thanks Meter: 15
thanks again to all the members for help .
Old 05-04-2011, 14:00   #12 (permalink)
Member: 1424514
thanks all the member
Old 05-05-2011, 13:52   #13 (permalink)
Member: 300368
Thanks Meter: 3
Wink
Thanks Bro...................
help after change 104 resister my lcd is blue pls help @@@___@@@ Chinese Models & Cloned Phones 2 03-14-2010 18:39
6030 lcd point is ground plz help me mobiletuch Nokia Hardware & Hardware Repair 0 12-30-2009 12:56
6030-LCD blue ligth rahmanp Nokia Hardware & Hardware Repair 3 07-15-2009 07:28
6030-LCD blue ligth rahmanp Nokia Hardware & Hardware Repair 1 08-07-2008 10:06
is work and is ok but it is blue lcd gsm-world Nokia Hardware & Hardware Repair 3 06-13-2008 13:58
Page generated in 0.21790 seconds with 11 queries
