Old 01-05-2007, 20:06   #1 (permalink)
Member: 185162
Thanks Meter: 10
6060 not charging
hello every1
plz gave me the solution for nokia 6060 its really urgent
Old 01-07-2007, 20:27   #2 (permalink)
Member: 101007
Thanks Meter: 27
does it show not charging?
if yes normally will be power ic prob
u can try write full pm b4 replace power ic
and if it doesnt show ayything when u plugin charger normally will be
fuse prob remove the fuze and make jumper
The Following 2 Users Say Thank You to uneternity For This Useful Post:
Old 01-08-2007, 05:07   #3 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
Clean Contacts, Write PM...
The Following User Says Thank You to Lhick For This Useful Post:
Old 01-12-2007, 13:07   #4 (permalink)
puneet14884's Avatar
Member: 399779
Thanks Meter: 125
Wink
write good pm first.....do post result
Old 01-12-2007, 13:39   #5 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
Bro, Test the GROUND and CHARGE IN it maybe shorted, If shorted replace V2000 diode, get diode from dummy board look for small to fit the contacts, check the diode with Digital meter, volts must be 5v or more.. its better. Good luck!
capri
Old 01-13-2007, 11:03   #6 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
@vishu222
Post your reply brother...
capri
Old 01-27-2007, 15:13   #7 (permalink)
mani_satcell's Avatar
Member: 65535
Thanks Meter: 451
first flash ur phone with pm file if not ready means check tracks to merge to ground otherwise change uem is the best solution asic2 rpl two handset ready for changing uem only for me
Old 05-28-2007, 12:19   #8 (permalink)
Member: 116572
Thanks Meter: 22
Thumbs up solved 6060 not charging
remove the chip resistor from bsi line its next to sim socket under the shielding
The Following 4 Users Say Thank You to irfansait For This Useful Post:
Old 09-12-2007, 21:46   #9 (permalink)
trycktill's Avatar
Member: 208709
Thanks Meter: 31
Thumbs up thanks
thanks problem solved but i need to chek if this can charge the battery or not ni will let you know
The Following User Says Thank You to trycktill For This Useful Post:
Old 09-12-2007, 22:16   #10 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Originally Posted by vishu222 View Post
hello every1
hello dear
please see picture
The Following 2 Users Say Thank You to BABAK NURI For This Useful Post:
Old 10-29-2008, 15:01   #11 (permalink)
zullu2004's Avatar
Member: 146635
Sonork: 100.1651273
Thanks Meter: 261
nokia 6060 displays STOP not charging
here is final solution for this problem
first try another battery, then see pictures 1,2,3
good luck
The Following 7 Users Say Thank You to zullu2004 For This Useful Post:
Old 10-29-2008, 16:01   #12 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
hello every1
Helo bro just do this your problem solve 90% tested by me
Flow the key pad side:
The Following 2 Users Say Thank You to Shantobhai For This Useful Post:
Old 10-30-2008, 04:49   #13 (permalink)
defrianto's Avatar
Member: 588260
Thanks Meter: 34
thank.........information
Old 03-16-2009, 07:32   #14 (permalink)
Member: 734746
thanxxxxxx
thaxxxxxxxxxxxxxxxxxxx
Old 10-29-2009, 14:04   #15 (permalink)
Member: 849903
good luck
good sollutos bro i tested it working 100%%%%%%%%%
thanks
The Following User Says Thank You to ukadure For This Useful Post:
6060 not charging plz hlp kifua Nokia Hardware & Hardware Repair 8 07-19-2008 10:57
solution for 6060 not charging celluniversal Nokia Hardware & Hardware Repair 5 07-19-2008 09:58
help 6060 not charging virrus Nokia Digital Core Technology 4 ( DCT-4 ) 0 08-23-2007 13:07
6060 not charging hisham786 Nokia Hardware & Hardware Repair 1 05-18-2007 07:22
6060 not charging very urgent naseer_10_1980 Nokia Digital Core Technology 4 ( DCT-4 ) 0 03-06-2007 08:42
Page generated in 0.24714 seconds with 10 queries
