6070 keypad not working Actually it was insert sim ...i sloved the problem by jumper solution.. After that keypad is not working ....i replaced front board and keypad ic too.. but not worked ... what to do???is keypad ic same as 6600???? help |
Use keypad Ic came from 3220,or 8310.7210,7250 if you have... |
plz check key pad ic |
can some tell me about 6070 no buzzer & speaker help me far |
brother change keypad connector |
Thanks JOJO problem is solved |
just reheat the upp with care ,100% ok if board is clean |
please help 6070 insert sim i has reflow sim ic but still has insert sim pppppppppppppppppppppppppppppp |
try to change a new sim ic, maybe can help you:D |
jumper is not a perfect solution try to replace the sim ic with new one . |
yeah, jumper will make the sim card work without protection , sim ic just work like a fuse system wich is save sim card from abnormal voltage. I guess?? :p |
plz i need help for the |
