05-10-2008, 00:20 | #2 (permalink) |
No Life Poster Join Date: Jan 2006 Location: EGYPT Age: 47
Member: 217479 Status: Offline Thanks Meter: 267 | First, please @ all technicians stop jumper solution since the spare parts is available. Second, @ tibcoalgerie, may you please explain your problem details & you will get many solution helps soon, for example your 6070 keypad problem may be due to UI keyboard or keypad connector on main board or side volume keys that affect badly on the keypad function & you can test that with removing both side volume keys at once then test the keypad function, also it may be processor UPP faulty & it need just a good reflow. B.R... |
The Following User Says Thank You to mobilagy For This Useful Post: |
nokia 6070 keypad problem | chhoton | Nokia Hardware & Hardware Repair | 16 | 02-23-2011 12:05 |
nokia 6070 keypad problem | sudheernik | Nokia Hardware & Hardware Repair | 4 | 08-24-2009 07:08 |
6070 keypad problem | pupaji | Nokia Hardware & Hardware Repair | 12 | 04-07-2009 12:41 |
6070 keypad problem | verlac dadz | Nokia Hardware & Hardware Repair | 7 | 01-25-2009 09:04 |
6070 keypad problem | Adityaram | Nokia Hardware & Hardware Repair | 4 | 09-24-2007 15:33 |
