12-14-2007, 07:37 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Pakistan Age: 41
Member: 616556 Status: Offline Thanks Meter: 112 | 6070 problem PLZ Help i Flash it Using UFS,flashing ok But UI Setting Failed,after flashing is completed the phones Shows"LOCAL MODE" phone shows information,Local Mode Test Mode are ok but normal mode failed Init Local Mode Ok, Time: 00:36 Init Test Mode Ok, Time: 00:07 Init Normal Mode Failed, Fatal Error i also make a self test here is result plz help urgant |
12-14-2007, 07:51 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | first try to flash it with other flasher like jaf.....if problem same then reball uem....ur prbl will solve good luck |
12-18-2007, 05:20 | #3 (permalink) |
Member: 616556 Status: Offline Thanks Meter: 112 | i have difficulty to iddentify the components on board of N6070 any one have pic or diagram lay out plz urgent |
The Following User Says Thank You to zahidnawaz For This Useful Post: |
Nokia 6070 "no operator found" problem.Plz help.. | jana1_2008 | Nokia Hardware & Hardware Repair | 8 | 10-06-2010 20:34 |
plz plz help 6030 strange problem plz help | bruightmobile | Nokia Hardware & Hardware Repair | 2 | 01-23-2010 06:24 |
Infinity update problems plz help help..help | ARIF GIGANI | Infinity-Box | 2 | 07-15-2009 20:17 |
nokia 6070 sir plz help......... | anil2006 | Nokia Hardware & Hardware Repair | 10 | 09-06-2008 08:27 |
