10-15-2008, 18:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | 6085 blue display? |
10-15-2008, 19:34 | #2 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | how u never succeed to repair any one. i have already received many 6085 with same problem, and in all case it was Flex. u never got one with Blue LCD who have Flex problem??!!!! anyway, u can check display ic. br |
10-15-2008, 19:55 | #4 (permalink) |
Insane Poster Join Date: May 2008 Age: 38
Member: 766363 Status: Offline Sonork: 58097562 Thanks Meter: 35 | try to do this: 1. first of all check with change flex cable (check in open with fit in bode). if not solve 2. then check with change lcd driver ic which is located at upper side of bottom jack, it is same as 6600 lcd driwer ic, if ur unable to change it then make jumper here, these jumper are also same as 6600/7610 display driwer ic jumper's but first of all, check ur handset is working well(means it receive of make call). then the problem is here if u r unable to make or receive calls it means ur software problem, so check where is problem and solve it, good luck... |
The Following 3 Users Say Thank You to Emmanuel 01 For This Useful Post: |
10-16-2008, 01:41 | #6 (permalink) |
Freak Poster Join Date: Sep 2007 Location: DIAMOND CITY
Member: 590041 Status: Offline Thanks Meter: 45 | some times i do receive this kind of fault this 6085.change flex still the same. pls i need a perfect solution for the ones not flex problem.thank U in advance |
10-28-2008, 05:00 | #9 (permalink) |
Insane Poster Join Date: May 2008 Location: tampico tamaulipas mexico
Member: 767213 Status: Offline Thanks Meter: 10 | i have same problem, lcd in blue, i try tu change, board lcd, lcd, flex and ic driver to lcd.check with nokia 6085 working good, the problem is in mother board. |
01-30-2009, 20:43 | #15 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | I flashed it with 'usb dead' method and it's working now,i never thought it's flash cause Even my reply is late but I think it's usefull |
The Following User Says Thank You to jawad8305 For This Useful Post: |
nk 6085 blue display | ashish mobile | Nokia Hardware & Hardware Repair | 12 | 09-10-2010 12:33 |
6085 blue display | smsismail | Nokia Hardware & Hardware Repair | 4 | 11-16-2009 06:00 |
6085 Blue Display , Please Try To Help Me,,,,,,,,,,,,,,,,,,,,, | munnachikku | Nokia Base Band 5 ( BB-5 ) | 3 | 06-01-2008 12:57 |
6085 blue display | rock01112 | Nokia Hardware & Hardware Repair | 3 | 04-19-2008 11:58 |
6085 blue display | vishal123123 | Nokia Hardware & Hardware Repair | 5 | 04-12-2008 19:58 |
