Old 12-05-2007, 08:10   #1 (permalink)
Member: 644306
6085 camera problem
the camera is not fuctioning can any one help me pls
Old 12-05-2007, 09:14   #2 (permalink)
GOODNESS's Avatar
Member: 89584
Thanks Meter: 68
change ur flex cable.if not okay,check ur camera
Old 12-05-2007, 13:52   #3 (permalink)
Member: 644306
I tried it but still same problem. It first goes black the out in the beging stage.
Old 05-28-2008, 14:19   #4 (permalink)
suntysunty's Avatar
Member: 226172
Thanks Meter: 946
Old 05-28-2008, 14:25   #5 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Yes dear,
Change the flex u r problem will be solve.
Post result.
Old 05-28-2008, 17:33   #6 (permalink)
chandy pok's Avatar
Member: 447590
Thanks Meter: 378
Just change LCD IC , The problem will be solved.Good luck.
Old 05-28-2008, 22:30   #7 (permalink)
Member: 756404
Thanks Meter: 28
6085 disply not working i change 2 dislplay ic problem not solved only blue light
pls help me
Old 05-29-2008, 08:02   #8 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
Try following
> Change Flex.
> Change LCD.
> Change LCD Connector.
Old 09-05-2008, 15:02   #9 (permalink)
Member: 511560
Thanks Meter: 66
tried all solutions above but solved. thanks for all.
Old 05-11-2009, 07:20   #10 (permalink)
Member: 644306
Nokia 5800
I have a Nokia 5800 where intermittently both camera are not working. I tried to give it a software update but still same problem.
6085 camera problem operation fail suntysunty Nokia Hardware & Hardware Repair 38 06-17-2010 15:48
nokia 6085 camera problem............ rk19801 Nokia Hardware & Hardware Repair 23 03-18-2009 09:48
Nokia 6085 camera problem wase Nokia Hardware & Hardware Repair 5 03-15-2009 07:56
nokia 6085 camera problem gulam khadir Nokia Base Band 5 ( BB-5 ) 1 11-04-2008 20:09
6085 camera problem chris_mark Nokia Hardware & Hardware Repair 3 01-02-2008 07:29
Page generated in 0.22559 seconds with 9 queries
