6085 display light 6085 dilplay light problem change display ic |
re: Quote:
' there is no link between display light & display ic" |
plz solution 6085 display light |
@mobilecarerke 1) Check with change Flex Cable if still 2) check with change other Lcd if still 3) you have to change Led ic. |
sir check the flex cable...if still problem persist change display ic...hope it can help i tried this already with my cp. |
change no display light .......same..... |
@mobilecarerke would you tell me its keypad leds will glow or not. if yes.then Resolder display connector. |
yes leds will glow , change complete upper with flex, check other handset upper ok, faulted pcb soulation, not be water in pcb |
6085 nokia dislay led light problem plz help me |
