6085 shows following massage 1st BOOT : C0,07 [Rm-198] RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 2A300219CC540058320B977A0512696EB3F42541 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1st Boot OK CMT 2nd Bt: RAP3Gv3_2nd.fg, Ver: 1.20.2 CMT 2nd Boot OK CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5 00000000: 02 00 00 00 00 D1 72 ......r ERR: CMT Alg Boot Alg Bodr: Process Failed, Repowering Mobile when connected to ufs 6085 shows following massage any solution............ |
brth try to flash it with jaf or mt if same then check in hardware problem in cpu or flash ic............good luck:) digitized |
First of all tell me which version of UFS Suite you are using. You must use HWK to successfully flash BB5 sets. If you are already using these, please check Dual Line option in UFS-HWK 2.0.6 and try. If it does not work, wash the board put some paste on UPP and Flash IC and apply adequate heat. Be carefull. Try and post result. Good Luck Bro! |
