Old 11-17-2007, 12:24   #1 (permalink)
totalmanish's Avatar
Member: 336192
Thanks Meter: 52
6085 shows following massage
1st BOOT : C0,07 [Rm-198]
RAPx ID : 000000010000022600010006010C192101001101
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx PBID : 2A300219CC540058320B977A0512696EB3F42541
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 191EC665DFAAF68F
CMT 1st Boot OK
CMT 2nd Bt: RAP3Gv3_2nd.fg, Ver: 1.20.2
CMT 2nd Boot OK
CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5
00000000: 02 00 00 00 00 D1 72 ......r
ERR: CMT Alg Boot Alg Bodr:
Process Failed, Repowering Mobile
when connected to ufs 6085 shows following massage any solution............
Old 11-17-2007, 14:55   #2 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,694
brth try to flash it with jaf or mt if same then check in hardware problem in cpu or flash ic............good luck
digitized
Old 12-17-2007, 11:36   #3 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,441
First of all tell me which version of UFS Suite you are using. You must use HWK to successfully flash BB5 sets. If you are already using these, please check Dual Line option in UFS-HWK 2.0.6 and try. If it does not work, wash the board put some paste on UPP and Flash IC and apply adequate heat. Be carefull. Try and post result.
Good Luck Bro!
6233 camera problem...hang(but not showing error massage broken_rules Nokia Hardware & Hardware Repair 19 09-17-2011 03:20
Dead nokia 3660 showing following message.. amit123 Nokia Hardware & Hardware Repair 2 05-12-2009 08:39
Dead Nokia 3310 Set Showing Following Informations... amit123 Nokia Hardware & Hardware Repair 0 03-31-2009 11:55
V3i Repair PDS show this massage. maheshsaiganesh Smart-Clip 2 06-23-2007 13:11
show this massage Error # 10054 probleme solved abhishek aga HWK 4 06-05-2006 11:52
Page generated in 0.20911 seconds with 8 queries
