6100, 1,2,3,4,5,6, key, pad,not work dear members, i really worried aboiut my mobile 6100, 1,2,3,4,5,6, key, pad,not work kindly send me anybody working solution. thanks in advace |
try to clean keypad surface,if not work.... change keypad ic |
its simple as changing keypad ic thats all mates |
first replace keypad ic.......post result regards PUNEET14884 :) |
check the keypad tracks with the same another 6100 board.. if all the tracks or ok... then u change the keypad ic.. if it is water damaged please clean well in petrol |
final solution just heat Upp |
replace keypad ic, if stillnot work reheat or reball your UPP |
the first check line in keyboad then check ic keyboard (replace) and then check cpu ( replace) |
change keypad ic if not work try to heat or replace upp |
plz check kypd ic n also chech gnd resistance b/w upp n ic also check upp |
Change Keypad Is First Then Check Again If The Problem Not Solved Just Re-ball The Cpu. |
