Old 03-30-2008, 09:49   #1 (permalink)
Member: 168346
Thanks Meter: 20
6100, 1,2,3,4,5,6, key, pad,not work
dear members,
i really worried aboiut my mobile 6100, 1,2,3,4,5,6, key, pad,not work
kindly send me anybody working solution.
thanks in advace
Old 03-30-2008, 09:59   #2 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 964
try to clean keypad surface,if not work.... change keypad ic
Old 03-30-2008, 10:16   #3 (permalink)
Member: 685445
Thanks Meter: 10
its simple as changing keypad ic thats all mates
Old 03-30-2008, 10:26   #4 (permalink)
puneet14884's Avatar
Member: 399779
Thanks Meter: 125
Arrow
Originally Posted by classic mobiles View Post
dear members,
thanks in advace
first replace keypad ic.......post result
regards
PUNEET14884
Old 03-30-2008, 18:45   #5 (permalink)
Member: 205776
Thanks Meter: 53
check the keypad tracks with the same another 6100 board.. if all the tracks or ok... then u change the keypad ic.. if it is water damaged please clean well in petrol
Old 03-31-2008, 03:12   #6 (permalink)
Member: 470074
Thanks Meter: 3
final solution
just heat Upp
Old 03-31-2008, 03:19   #7 (permalink)
Member: 683463
Thanks Meter: 185
replace keypad ic, if stillnot work reheat or reball your UPP
Old 03-31-2008, 03:47   #8 (permalink)
Crazy Poster
Member: 506016
Thanks Meter: 2
the first check line in keyboad then check ic keyboard (replace) and then check cpu ( replace)
Old 03-31-2008, 04:02   #9 (permalink)
Member: 511502
Thanks Meter: 2
change keypad ic if not work try to heat or replace upp
Old 03-31-2008, 07:39   #10 (permalink)
ranji's Avatar
Member: 670594
Thanks Meter: 51
plz check kypd ic n also chech gnd resistance b/w upp n ic also check upp
Old 03-31-2008, 08:28   #11 (permalink)
Member: 244357
Thanks Meter: 70
Change Keypad Is First Then Check Again If The Problem Not Solved Just Re-ball The Cpu.
6233 key no 1,,2,3,4,5,6,7,8,9,*,#0 not working rohit50 Nokia Hardware & Hardware Repair 8 11-30-2009 19:20
sir 6233 menu,ok,opton and above all upper key working but 1 to 9 keypad (1,2,3,4,5,6 alkesh02 Nokia Base Band 5 ( BB-5 ) 6 09-23-2009 17:52
1600:key1,2,3,4,5,6 not working beneto Nokia Hardware & Hardware Repair 6 04-12-2008 05:19
k5o8 keys "ok,1,2,3,4,5,6 r not working mouse is ok khurram786 Sony Ericsson Hardware Repair 2 01-22-2008 18:20
Page generated in 0.42660 seconds with 8 queries
