02-21-2005, 22:22 | #1 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Estonia Age: 46
Member: 6208 Status: Offline Thanks Meter: 12 | 6100/3100 Flash IC Can i use flash from 6310 (i640W18TD)? Or flash from 8310 ( iF640W18T)? Or flash from 7210 ( K8S64158TM)? Or flash from Ngage ( N643GT7MI)? Problem was, the phone losed the network. First i flashed it with new firmware, no success. Then I reheated the PCB, all parts, and phone was dead. I tried to flash it, twiser said :UPP ok, boot also ok, but after flash erase, in 10% flashing error. With Griffin also same problem, flash erase ok, but in first 10% error(connection lost ors). I think i must change the flash ic, cause first, when the problem with network begin, phone also freezed and rebooted. Or what should be the solution. Any help will be great. |
02-22-2005, 07:57 | #3 (permalink) |
Member: 6208 Status: Offline Thanks Meter: 12 | Ok. I try that. But its more comfortable to put the new flash chip to the phone. I may be killed CPU with overheat? But then phone i think were totally dead - no communication with twister(it says UPP OK) and no start to flash erase. Problem is, those original flash ic's are out of stock from my supplyer. Pls, help |
02-22-2005, 12:19 | #4 (permalink) |
Member: 6208 Status: Offline Thanks Meter: 12 | Solution to fix such problem(i guess not only for 6100/3100, also other dct-4) is change UPP. Twister said, before i changed UPP: 1st Boot Ok, DCT4, UPP: 1120 FlId Aliasing with: 00EC22F0 Fl0: 0x01000000-0x017FFFFF,00EC22F2,Sam K5U64418TM Algorithm: u_amd.fia Algorithm Ok, MSID: 84DF1EAFB0AC61DAAFD3167073 Decoded MSID: 516EBAE9-00C3E53C-A9000000 Encoded FAID: 983BA2C1-41083ED7-995FE4AB Area1: 0x01000000-0x0100FFFF Erased, Time: 0:00 Area2: 0x01010000-0x0154FFFF Erased, Time: 0:43 Area3: 0x01680000-0x017EFFFF Erased, Time: 0:12 Area4: 0x01EB0000-0x01FEFFFF Out of Chip Bounds Write Error: hDat 14, at: 0x01040000:08 Process Failed, Repowering Mobile There is no problem with flash and UEM. Good luck. I got phone worked. Old UPP was 4370931 and i canged to 4370873. working OK. But i have still question - what kind flash types i can use in 3100/6100? |
02-22-2005, 19:40 | #6 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Fahad Al Salem, Kuwait Age: 42
Member: 63385 Status: Offline Thanks Meter: 3 | Check which flash version u are using... Try to flash with higher version 'coz i had d same problem with 61/3100 before and just solve it flashing with higher version. Check i the support site for the flash files. Chill! merulez29 |
02-23-2005, 06:40 | #8 (permalink) | |
Member: 6208 Status: Offline Thanks Meter: 12 | Quote:
To reball the flash is real pain in my ***, thats why i thought to put the new, reballed flash ic, to the phone. Original IC was out of stock of my supplier, and my toughts were simple - what flash IC can i use. I hope you i-mobile are right. I try this next time. I let you all guys know my experiens too. It were very helpful, if somebody wrote here the same - clearly what IC exactly and what phone No hard feelings | |
02-23-2005, 08:47 | #9 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Beograd Age: 48
Member: 80255 Status: Offline Thanks Meter: 15 | Use flash ic from 7250i, 3200 3300 (combo flash- whit ram inside) can use flash from 7210 who gatno RAM on board. Network problem cause cpu (v826-4370931) and uem (write asic2 rpl), if change flash ic write good PM (if bad is low signal or cant find network. When chaking network use manual search if searching long time uem posibile is good just write new PM. Best gegards |
05-12-2005, 14:13 | #11 (permalink) |
No Life Poster Join Date: Dec 2001 Location: In front of my computer
Member: 7741 Status: Offline Thanks Meter: 111 | i already change PA, Antenna Switch, CPU, UEM still no network. before changing the parts, the phone have pcn fluctuating signals. But Now the phone have signal bars (but there is no fluctuating signal from the phone and then in 2 seconds the phone totally have no network on both gsm and pcn). Towmorrow i will change the flash chip + UEM and test for results and write the rpl. Hope tomorrow the phone will back to network on both pcn and gsm. |
is 3100 flash ic working in 6100 please help me | shivam4you | Nokia Hardware & Hardware Repair | 10 | 12-05-2008 10:12 |
Nokia 3100 flash Ic changing | mobilelink | Nokia Hardware & Hardware Repair | 11 | 08-12-2007 08:15 |
6100 Flash ic info needed | Anno | Nokia Hardware & Hardware Repair | 3 | 10-01-2004 04:46 |
Nokia 6100 flash IC compatibles ...?? | Medz | Nokia Hardware & Hardware Repair | 0 | 03-27-2004 18:46 |
