04-17-2005, 18:18 | #2 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: www.sevgigsm.net Erkan Yasar Age: 61
Member: 81576 Status: Offline Thanks Meter: 2,128 | Quote:
good PM to find | |
04-17-2005, 19:17 | #4 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: Milano, Italy Age: 37
Member: 62336 Status: Offline Thanks Meter: 115 | Quote:
after do Full factory default & init sim locks. | |
06-18-2005, 16:59 | #7 (permalink) | |
Freak Poster Join Date: May 2005 Location: ksa Age: 52
Member: 149600 Status: Offline Thanks Meter: 11 | Quote:
08-17-2005, 07:42 | #8 (permalink) |
Freak Poster Join Date: Jan 2004 Location: UK -Leicester
Member: 51517 Status: Offline Thanks Meter: 24 | i'v got the same problem, and still no difference after flashing with PBB (and les after flashing goes to test mode, NOT local mode): when connected to flasher if tell it to goto normal mode, it goes but i get an error on the Phoenic prog saying: "The mode refresh request failed. The product is in the middle of a mode transition." about the switch: it does work as the phone switches on and off (but into contact service mode only) i checked it's connections: switch to ground ok - No resistance between switch - No resistance across it when switch pressed switch to R306 Resister - No resistance between R306 Resister - 27K ohm as it should be C310 capacitor - donno how to test that! is there anything else i can try or have i missed something? thanks, Lad. Last edited by LAD; 08-17-2005 at 08:48. |
k310i. CID49 flashing 'n unlock OK but cannot turn on | danau_ranau | SETool2 | 1 | 01-12-2009 15:49 |
W300i - flashing OK - but won't turn on | mahcin | Cruiser Suite | 5 | 05-23-2008 23:59 |
6100 flash ok, but not power on, please help | kaholukkk | Nokia Hardware & Hardware Repair | 3 | 08-23-2006 17:37 |
6100 Flashing Ok But No Power On | celluniversal | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 03-01-2006 15:34 |
