08-24-2004, 08:49 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Croatia Age: 48
Member: 14602 Status: Offline Thanks Meter: 18 | 6100 flashing error 44449100 help please... using autopower Initializing Phone... Error[44449100] and that's all folks... i read something about it...and some post says that the phone flash chip is broken....sorry on bad english....if there is any solution to repair this phone help please...i worked many 6100 before this one... i also have the same case with one 3650.... |
08-24-2004, 12:31 | #2 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | 1- check cable 2- check if its water damaged 3- and not all that eror meant flash damaged it might b uem if you experinced in hardware work you can check bothe the uem and flash chip |
08-24-2004, 16:14 | #3 (permalink) |
Member: 14602 Status: Offline Thanks Meter: 18 | what is a "UEM" and which one is "FLASH" and what to do to repair it...? do i have to replace it? any schematic or service manual for 6100...where can be found? thnx! B.R. |
08-24-2004, 16:54 | #4 (permalink) |
Member: 7062 Status: Offline Thanks Meter: 126 | hi freind did you checked the cable and the data pin did you checked the phone if any of water trace inside board check this first please befor we go further please |
08-24-2004, 17:55 | #5 (permalink) | |
No Life Poster Join Date: Jun 2002 Location: Morocco, Rabat Age: 45
Member: 12504 Status: Offline Thanks Meter: 10 | Quote:
08-24-2004, 23:28 | #6 (permalink) |
Member: 14602 Status: Offline Thanks Meter: 18 | i cheked and cable and i cheked for water and its all fine because i have griffin gold and it's works fine with 6100 before and after this one.phone is new and it's come to me to flash lang pack with croatian language.after first flashing the phone turn on but nothing was on display and only light was working...and it was a dark display.I also flashed and cp file.so i go on flashing once again mcu +ppm without cp file and after that the phone is dead and griffin doesn't communicat with phone..also 3650 same case... |
k510i red 49 flashing error every time please help | adnanshahzad | Cruiser Suite | 22 | 11-05-2007 16:03 |
6100 flashing error in UFS 3 | sonucellking | Nokia Multimedia | 0 | 12-03-2006 11:06 |
6100 flashing error help please... | mmanduri | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 08-24-2004 08:46 |
CS Error, 3310.445 flash file repair help please | bre786 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 11-11-2001 10:27 |
