6100 not power on!!!!! hello i have a 6100 when i try to power on ....nothing i try to flash it, it flash ok it comuniacate with pc well but not switch on!! can anybody tell me what to do to fix this? thanks :confused: |
Check the switch or try to change LCD... Chill! merulez29 |
twister! i flash the phone with last version! but still no power on! :confused: |
switch and lcd r good!! |
check "Mobile INFO" by your twister and put here screenshot. Does the phone react when you try to charge it? check for liquid and mechanical damages. |
MCU Sw: V 04.70 23-04-03 NPL-2 (c) NMP. PPM Sw: V 05.16 26-09-03 NPL-2 (c) NMP C Prd.Cd: 0509148 Bpr.Cd: 0508109 Pro.Sn: 2EC059495 HW : 0581 PCI : 0 UEM : 8 UPP : 4384 RFIC : 0300 DSP : 7.70-4.40 LCD : SED15G10 IMEI : 350991-20-101755-1 SLconf: 001-01-00000000000 SLprof: 000000000000000-2 SLvar : 00553509912010175500 SLaux : 00020000 Provider: Test Equipment #pw+ 019 993 537 761 001 +1# #pw+ 313 456 232 146 063 +2# #pw+ 755 820 271 340 630 +3# #pw+ 134 334 057 265 046 +4# #pw+ 839 011 450 772 427 +5# #pw+ 988 862 500 660 073 +6# #pw+ 227 505 645 507 113 +7# here is info with twister! yes |
when i conect charger nothing hapend! man the pone first when i put the batery in the lcd show local mode! and after that the never power on! :confused: :confused: |
try to reball UEM be carefull about broken green layer under UEM |
if the phone sets in local mode when you put the battery in, it means: 1) battery problem - low resistance between GND and BSI - replace the battery and check result. 2) hw problem - check battery connector and uem circuits for liquid damage. |
