Old 02-22-2005, 16:41   #1 (permalink)
Member: 98081
Thanks Meter: 28
Red face 6100 not power on!!!!!
hello
i have a 6100 when i try to power on ....nothing
i try to flash it, it flash ok
it comuniacate with pc well but not switch on!!
can anybody tell me what to do to fix this?
thanks
Old 02-22-2005, 19:47   #2 (permalink)
Member: 63385
Thanks Meter: 3
Check the switch or try to change LCD...
Chill!
merulez29
Old 02-22-2005, 22:14   #3 (permalink)
fonecellar's Avatar
Member: 545165
Thanks Meter: 578
Originally Posted by lucik
hello
thanks
what are you using to flash????
Old 02-23-2005, 09:16   #4 (permalink)
Member: 98081
Thanks Meter: 28
twister!
i flash the phone with last version!
but still no power on!
Old 02-23-2005, 09:17   #5 (permalink)
Member: 98081
Thanks Meter: 28
Chill!
merulez29
switch and lcd r good!!
Old 02-23-2005, 12:47   #6 (permalink)
Masta G.'s Avatar
Member: 46415
Thanks Meter: 16
check "Mobile INFO" by your twister and put here screenshot.
Does the phone react when you try to charge it?
check for liquid and mechanical damages.
Old 02-23-2005, 12:53   #7 (permalink)
fonecellar's Avatar
Member: 545165
Thanks Meter: 578
twister!
can you put into local mode after flash with phone attatched to box???
Old 02-23-2005, 16:59   #8 (permalink)
Member: 98081
Thanks Meter: 28
MCU Sw: V 04.70 23-04-03 NPL-2 (c) NMP.
PPM Sw: V 05.16 26-09-03 NPL-2 (c) NMP C
Prd.Cd: 0509148
Bpr.Cd: 0508109
Pro.Sn: 2EC059495
HW : 0581
PCI : 0
UEM : 8
UPP : 4384
RFIC : 0300
DSP : 7.70-4.40
LCD : SED15G10
IMEI : 350991-20-101755-1
SLconf: 001-01-00000000000
SLprof: 000000000000000-2
SLvar : 00553509912010175500
SLaux : 00020000
Provider: Test Equipment
#pw+ 019 993 537 761 001 +1#
#pw+ 313 456 232 146 063 +2#
#pw+ 755 820 271 340 630 +3#
#pw+ 134 334 057 265 046 +4#
#pw+ 839 011 450 772 427 +5#
#pw+ 988 862 500 660 073 +6#
#pw+ 227 505 645 507 113 +7#
here is info with twister!
yes
Old 02-23-2005, 17:02   #9 (permalink)
Member: 98081
Thanks Meter: 28
when i conect charger nothing hapend!
man
the pone first when i put the batery in
the lcd show local mode!
and after that the never power on!
Old 02-23-2005, 17:18   #10 (permalink)
SPUnlock_SK's Avatar
Member: 13922
Thanks Meter: 308
try to reball UEM be carefull about broken green layer under UEM
Old 02-23-2005, 17:31   #11 (permalink)
fonecellar's Avatar
Member: 545165
Thanks Meter: 578
man
O.K now i think you can safley say you have a battery or h/ware/ board problem, I know this sounds silly but try another battery, when you connect charger, phone should show charging, if not clean board,
Old 02-24-2005, 14:36   #12 (permalink)
Masta G.'s Avatar
Member: 46415
Thanks Meter: 16
if the phone sets in local mode when you put the battery in, it means:
1) battery problem - low resistance between GND and BSI - replace the battery and check result.
2) hw problem - check battery connector and uem circuits for liquid damage.
6100 not powering on with battery astana2007 Nokia Hardware & Hardware Repair 4 06-28-2009 12:29
6100 flash ok, but not power on, please help kaholukkk Nokia Hardware & Hardware Repair 3 08-23-2006 18:37
6100 can not power on after flashing 100% hooi76 Nokia Hardware & Hardware Repair 8 06-18-2006 04:08
t100 not power on after flash, not power on when original cable is plug GYZMO VLSI, Conexant, Skyworks and Old Models 8 01-07-2004 00:34
Page generated in 0.40832 seconds with 8 queries
