10-28-2004, 13:08 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | 6100 works on test jig only ...!!! |
11-10-2004, 07:04 | #3 (permalink) | |
Member: 39208 Status: Offline Thanks Meter: 152 | Quote:
i try your solution but nothing changed ... | |
11-28-2004, 02:49 | #6 (permalink) |
Freak Poster Join Date: Mar 2003 Location: MNE Age: 43
Member: 23848 Status: Offline Thanks Meter: 13 | probably it`s more simple that you think Did you try to power on the phone on wires while in chasis?Yes-you need a resistor between tne GND pin and the BSI,I think that a 10K will do the job.If the phone turns on-probably the battery pins are the problem,especially teh middle one.Try to stick them out but not to beak them.If it not turns on-try re-heating or reballing the UEM and/or the CPU. Sincerly I think that you don`t have to heat anything... Good luck |
11-28-2004, 20:24 | #8 (permalink) | |
i will try your solution and post result .. BR BYTE | |
6020 works on the cable only | sezief | Nokia Hardware & Hardware Repair | 10 | 10-19-2011 10:50 |
E800 works on 2 networks only? | butigood | SYSOL Platform | 0 | 06-30-2006 13:25 |
3310 Works on test jig ONLY ... !!!! | Byte | Nokia Hardware & Hardware Repair | 4 | 12-04-2004 16:46 |
powers on test jig only ...!!! | Byte | Nokia Hardware & Hardware Repair | 2 | 08-01-2004 00:08 |
