Old 09-05-2006, 13:42   #1 (permalink)
aLeN27's Avatar
Member: 10448
Exclamation !!!!!!!!!!!!! 6101 display blinking problem !!!!!!!!!!!!!!!!
when i power on the phone everything working well but only two display is blinking on every 5 sec.
i was change the two display with new one and also the flex cable.but same problem again.
my customer havent say to me but i thing phone was drop to water.
i was search all topic on our forum but no solution.
any body have a idea for thise problem.
B.R.
BGTGSM
Old 09-05-2006, 16:06   #2 (permalink)
aLeN27's Avatar
Member: 10448
where is collective work ?
Old 09-05-2006, 18:30   #3 (permalink)
aLeN27's Avatar
Member: 10448
halooooooooooooooooo
Old 09-05-2006, 20:19   #4 (permalink)
GsmTracer's Avatar
Member: 279960
Thanks Meter: 56
try to reflow the ic's on LCD pcb.
Old 09-06-2006, 10:37   #5 (permalink)
aLeN27's Avatar
Member: 10448
thanks for answer but i reflow it and also main pcb but same problem
Old 09-07-2006, 10:04   #6 (permalink)
aLeN27's Avatar
Member: 10448
any more idea ???.i need real solution ?
Old 09-07-2006, 15:04   #7 (permalink)
Member: 111028
Try to change UI Module assy. Should help 90%.
B.R.
carloz
Old 09-11-2006, 18:58   #8 (permalink)
thecult's Avatar
Member: 9700
Thanks Meter: 62
Hi, I have tried all solutions, also tried to change entire display pcb and flex, no solution.
I'm thiniking about defective spare displauys?????
wbr
thecult
Old 09-15-2006, 15:36   #9 (permalink)
Member: 148029
Thanks Meter: 9
i have same complint 6101. its happening only with duplicate display. if i change original working ok
Old 09-20-2006, 11:39   #10 (permalink)
Member: 37746
I have two displays. First mark LPH8877T002 and working perfectly, second mark LPH8877T001 and blinking. I think of two variants of one type. I'is right?
Old 10-07-2006, 11:39   #11 (permalink)
Member: 193660
Thanks Meter: 3
hello... I have the same problem - both displays are blinking - after I changed the external LCD... anyone have the solution?.. thanks
Old 10-09-2006, 19:49   #12 (permalink)
microera's Avatar
Member: 4923
Thanks Meter: 74
I have same problem..after changing both LCD display (inner and outer) picture on 6101 allways blink (white background) every 5 s for time of 1 s!
Old 10-09-2006, 21:34   #13 (permalink)
uppwd2's Avatar
Member: 115864
Thanks Meter: 8
Hi
Replace sub LCD with 6170 it will solve your problem and after that 6101 & 6170 will work perfect.
Old 10-10-2006, 12:33   #14 (permalink)
microera's Avatar
Member: 4923
Thanks Meter: 74
you mean:
smaller LCD must replace with LCD of 6170?
Old 10-12-2006, 12:03   #15 (permalink)
hafizjee's Avatar
Member: 234653
Thanks Meter: 83
6101 blinking display
hi
sir,reheat the cpu it will be 100% ok
The Following 2 Users Say Thank You to hafizjee For This Useful Post:
5610d display blinking problem Afzal Chiri Nokia Hardware & Hardware Repair 9 07-03-2012 14:29
nokia 6111 display blinking problem kwikcell Nokia Hardware & Hardware Repair 5 05-11-2009 12:59
6101 Display Blinks Mumt@z c",) Nokia Hardware & Hardware Repair 7 03-18-2009 09:12
6101 display blink after flash aakif_nab Nokia Hardware & Hardware Repair 0 02-26-2007 21:02
Page generated in 0.24916 seconds with 10 queries
