09-09-2008, 19:30 | #1 (permalink) |
Insane Poster Join Date: Sep 2006
Member: 341975 Status: Offline Thanks Meter: 24 | 6101 side volume switches I tried using hot air and a soldering iron to reattach the switches to the board, but the inside parts of the switch are plastic and deform. What temperature settings on the hot air station or soldering iron should be used to melt the solder, but not the switch itself. |
09-09-2008, 19:37 | #2 (permalink) |
Registered User Join Date: Aug 2006
Member: 324865 Status: Offline Thanks Meter: 12 | 6101 solution brother u must use a soldering iron,but b4 u place the button u must use a little flux on the contacts.components hold on better wen the solder on the surface shines hop this helps |
The Following User Says Thank You to ps cellular For This Useful Post: |
nokia 6120c side volume switch tracks | suchitra225807 | Nokia Hardware & Hardware Repair | 4 | 05-08-2011 15:42 |
6233 side volume keys not work. | maheshsaiganesh | Nokia Hardware & Hardware Repair | 4 | 11-29-2009 10:10 |
6270 Side Volume Switches & camera Switch not working | broken_rules | Nokia Hardware & Hardware Repair | 1 | 02-12-2009 10:27 |
6230i Side Volume Butten Doesnt Work Plzz Help | MOHMEDPMB | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 10-11-2007 09:28 |
3310,8210 Power switch solution. 6610 volume switch solution(NEED HELP) | smartfone | Nokia Hardware & Hardware Repair | 7 | 09-15-2006 06:29 |
