6101 white lcd flicker... Replaced both lcd's after phone was dropped. Now inner lcd flickers every 5 secs, even on standby. Outer lcd flickers constantly. ANY idea?? PLEASE help |
have you replaced the flex cable.also had phone with same problem and when i changed flex it worked fine. |
That is right!!!!!!!!!!!!!!!!!!!!!!! good luck!!!!!!!!!!!! |
must change LCD connecting plate. Then its work. |
just you change lcd and engy for all time |
Same pb. here....I change 2 flex cable ......the main lcd only one time flicker and then turn off.........but the back display is ok.....What is the pb.. Thanks. BR. Faisal. Opal Mobiles. |
i had the same problem guys i changed the lcd board.phone working 100% |
Generic LCD modules cause the flickering issue Regards D. |
if use 6170 display to 6101 you will get this flickering issue |
just change the lcd board 100% ok |
try change LCD 1st... if cant change LCD broad |
i have also the same problem here 6101 lcd flicker water damage i have change the lcd but the same result..both lcd inside and outside flickers in every 5 secs |
i have the same problem... but still theres no good solution... were still waiting........ wbr |
reheat lcd ic the small crystal |
