Old 05-29-2006, 21:16   #1 (permalink)
Member: 69633
Thanks Meter: 2
Red face 6101 white lcd flicker...
Replaced both lcd's after phone was dropped. Now inner lcd flickers every 5 secs, even on standby. Outer lcd flickers constantly.
ANY idea??
PLEASE help
Old 05-30-2006, 11:41   #2 (permalink)
W4r10rD's Avatar
Member: 183043
Thanks Meter: 68
have you replaced the flex cable.also had phone with same problem and when i changed flex it worked fine.
Old 05-30-2006, 11:55   #3 (permalink)
THONG GSM's Avatar
Member: 266621
Thanks Meter: 3
That is right!!!!!!!!!!!!!!!!!!!!!!!
good luck!!!!!!!!!!!!
Old 08-09-2006, 09:48   #4 (permalink)
Member: 256978
Thanks Meter: 72
No Helps. Flex cable its fine. Replaced 2x. Nothing happent.
must change LCD connecting plate. Then its work.
Old 08-09-2006, 12:54   #5 (permalink)
Member: 285377
Thanks Meter: 7
just you change lcd and engy for all time
Old 08-23-2006, 09:56   #6 (permalink)
faisi's Avatar
Member: 143322
Thanks Meter: 35
Same pb. here....I change 2 flex cable ......the main lcd only one time flicker and then turn off.........but the back display is ok.....What is the pb..
Thanks.
BR.
Faisal.
Opal Mobiles.
Old 08-23-2006, 09:58   #7 (permalink)
Member: 45716
Thanks Meter: 38
i had the same problem guys i changed the lcd board.phone working 100%
Old 11-24-2006, 08:11   #8 (permalink)
DMD
DMD's Avatar
Member: 12660
Thanks Meter: 7
Generic LCD modules cause the flickering issue
Regards D.
Old 11-24-2006, 10:06   #9 (permalink)
Member: 34379
Thanks Meter: 96
if use 6170 display to 6101 you will get this flickering issue
Old 11-24-2006, 15:00   #10 (permalink)
Crazy Poster
Member: 206394
just change the lcd board 100% ok
Old 11-24-2006, 20:54   #11 (permalink)
Member: 320354
Thanks Meter: 48
try change LCD 1st...
if cant
change LCD broad
Old 01-22-2007, 05:46   #12 (permalink)
Member: 16739
i have also the same problem here 6101 lcd flicker water damage
i have change the lcd but the same result..both lcd inside and outside flickers in every 5 secs
Old 01-22-2007, 05:50   #13 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
Try to clean again the Board & let it Dry in a Warm Condition. Board is shorted.
Old 01-23-2007, 07:31   #14 (permalink)
GSM_BLUE's Avatar
Member: 356202
Thanks Meter: 46
i have the same problem... but still theres no good solution... were still waiting........
wbr
Old 01-23-2007, 07:40   #15 (permalink)
keaelite's Avatar
Member: 288470
Sonork: 100.1605122
Thanks Meter: 664
reheat lcd ic the small crystal
Nokia 6101 white lcd yessine Nokia Hardware & Hardware Repair 1 07-20-2009 18:21
nokia 6101 white lcd solution blink talent lsurasak Nokia Hardware & Hardware Repair 4 08-27-2008 12:24
6300 LCD flickering Pardoon Nokia Hardware & Hardware Repair 5 08-10-2008 13:06
Nokia 6060 LCD Flickers balouch Nokia Hardware & Hardware Repair 3 07-31-2006 06:53
D500 Lcd Flicker After Standby cyrenity Samsung Hardware Repair 2 03-08-2006 03:30
Page generated in 0.70687 seconds with 8 queries
