Old 12-17-2007, 13:18   #1 (permalink)
Member: 146369
Thanks Meter: 119
6120 White blinking LCD/blank
Can anyone provide me with the solution to 6120??
It came in to me dead after it was dropped from 3m... I have now reflowed the PCB, and it came back from the dead... Now it can turn on, but display is blinking white a few times, then it shows the Nokia logo upsides down, I hear the Nokia tune, and then it goes blank...
Hope anyone can provide me with a solution...
Wbr
Old 12-17-2007, 16:00   #2 (permalink)
Member: 247232
Thanks Meter: 17
sorry can't answer to your problem! Wat you need is a full understand on how the phone works! else you are doing a trial and error!
Old 12-29-2007, 14:03   #3 (permalink)
Member: 511560
Thanks Meter: 66
maybe you can change the display ic, good luck
Old 01-14-2008, 13:43   #4 (permalink)
Member: 63030
Thanks Meter: 8
Flash the phone with jaf.
Old 07-30-2008, 06:51   #5 (permalink)
Member: 21937
Thanks Meter: 279
having same problem after water damage , phone led and lcd blinking ....
i change all 3 ic's near lcd connector , same problem . but what it seem problem comes from betty ic.
i rehot ic , blinking stoped . but now i have missing leg on the uper ic i hope i can fix it.
Old 07-30-2008, 06:57   #6 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
not solutions.................!
Old 07-30-2008, 09:14   #7 (permalink)
Member: 21937
Thanks Meter: 279
o.k
i have fixed my phone
rehot betty ic , and make jumper like E65 lcd jumper on the uper ic near lcd connector.
i have also changed 2 other ic's on the side just in case
phone is working again , not blinking.
hope it helps
The Following User Says Thank You to TRABEL For This Useful Post:
Old 07-30-2008, 09:42   #8 (permalink)
MSCOMMUNICATION's Avatar
Member: 190947
Sonork: 100.96272
Thanks Meter: 161
Thumbs up 6120c rm-243
6120c rm-243 file selection
ms communication pakistan
The Following 2 Users Say Thank You to MSCOMMUNICATION For This Useful Post:
Old 08-25-2008, 19:41   #9 (permalink)
Don_R's Avatar
Member: 256801
Thanks Meter: 49
Originally Posted by TRABEL View Post
o.k
hope it helps
Can u post a picture of that jumper
Old 01-13-2010, 03:43   #10 (permalink)
Member: 21863
Thanks Meter: 13
thanks bother gooooooood work & goooooood team
Old 01-21-2010, 17:47   #11 (permalink)
X-TRA's Avatar
Member: 303790
Thanks Meter: 290
can any one confirm me is that a perfect solution any one test it with these files
Old 01-22-2010, 23:42   #12 (permalink)
maher_asif's Avatar
Member: 330136
Thanks Meter: 37
6120
brother 1st erase e66 eno file
then normal flash
e66 eno file blank 514kb
chehck it
reply me
Old 03-20-2011, 09:46   #13 (permalink)
Member: 335640
then normal flash
chehck it
reply me
Thank you. Helped me.
Old 04-11-2011, 11:10   #14 (permalink)
Crazy Poster
Member: 1249417
Thanks Meter: 4
not werk for me please help me show nokia and blink plese help me i changed bt ic and power ic also
Old 04-12-2011, 10:09   #15 (permalink)
sathvik71052's Avatar
Member: 549926
Thanks Meter: 118
Br some times flshing ok ui settings ok but phone will restart try with higher version again samr problem 100 percent blutooth ic just remove bt ic 100 percent tested.........
6120 lcd blank mubash_oachira Nokia Hardware & Hardware Repair 1 12-08-2009 19:55
6120 after drop only white blink and shows animations Crazy_ratata Nokia Hardware & Hardware Repair 6 11-13-2008 20:28
white blink white lcd k800! .:bono:. KULANKENDI Server 2 05-03-2007 14:26
3230 white screen and Blinking lcd skd_123 Nokia Hardware & Hardware Repair 3 07-15-2006 15:46
6630 - 4X blinking Nokia/ Blank White screen - MCU Info invalid! Burnt Cobba Nokia Base Band 5 ( BB-5 ) 2 02-10-2006 12:45
Page generated in 0.21198 seconds with 11 queries
