Old 11-14-2007, 11:39   #1 (permalink)
Member: 127405
Thanks Meter: 11
6120c light problem
Please any solution to repair light problem in nokia 6120c
regards
The Following 5 Users Say Thank You to ***GSM-LONI*** For This Useful Post:
Old 12-12-2007, 12:28   #2 (permalink)
shachash's Avatar
Member: 51905
Thanks Meter: 41
same problem here brand new phon no light
The Following User Says Thank You to shachash For This Useful Post:
Old 01-20-2008, 14:04   #3 (permalink)
shachash's Avatar
Member: 51905
Thanks Meter: 41
any solution yet? please someone..
Old 02-07-2008, 10:13   #4 (permalink)
Member: 15593
Thanks Meter: 19
6120c Light
Hello,
i have a brand new phone it dont have light on display and keypad. Can somebody help??? I have download the schematic but i cant find the failure.
Please help.
thanks
noko
The Following 3 Users Say Thank You to noko For This Useful Post:
Old 02-21-2008, 13:16   #5 (permalink)
Member: 461923
Thanks Meter: 2,015
..succes..........................
The Following 50 Users Say Thank You to stefani For This Useful Post:
Old 02-01-2009, 13:31   #6 (permalink)
Member: 899568
Thanks Meter: 12
pls send me position of display light ic,
friend iam new in this field
The Following 2 Users Say Thank You to aslam papaiya For This Useful Post:
Old 02-01-2009, 14:57   #7 (permalink)
asimbutt's Avatar
Member: 394146
Thanks Meter: 56
By changing N2300 it will work 100%.....
The Following 2 Users Say Thank You to asimbutt For This Useful Post:
Old 02-01-2009, 15:27   #8 (permalink)
Member: 286908
Thanks Meter: 81
this is correct solution
6120c light problem will solve 100% change BETTY orginal one
6120 no have spacial led driver ic there is two dual transistors only
almost light problem will solve change betty ic
The Following 4 Users Say Thank You to santhosh kerala For This Useful Post:
Old 02-01-2009, 17:19   #9 (permalink)
Member: 803104
Sonork: 100.1664442
Thanks Meter: 25
go to settings then to display settings then to backlights then u will see wheather is of or extended or normal just activate normal
The Following 2 Users Say Thank You to francis10gh For This Useful Post:
Old 02-01-2009, 17:25   #10 (permalink)
Member: 803104
Sonork: 100.1664442
Thanks Meter: 25
The Following 3 Users Say Thank You to francis10gh For This Useful Post:
Old 04-21-2009, 09:42   #11 (permalink)
gokul2005's Avatar
Member: 169384
Thanks Meter: 109
its working 10000%.......tested by me
The Following 3 Users Say Thank You to gokul2005 For This Useful Post:
Old 05-20-2009, 09:58   #12 (permalink)
d2m
Member: 906086
Thanks Meter: 3
tanx . tested by me . . .ok
The Following 2 Users Say Thank You to d2m For This Useful Post:
Old 05-20-2009, 17:39   #13 (permalink)
aravimobile's Avatar
Member: 602589
Sonork: 0000001
Thanks Meter: 821
change betty it 100%ok
The Following 2 Users Say Thank You to aravimobile For This Useful Post:
Old 05-20-2009, 20:24   #14 (permalink)
Member: 1028413
Sonork: 8.01untiring
Thanks Meter: 3
pl change charging ic(betty)same73 100%ok
The Following 2 Users Say Thank You to anee For This Useful Post:
Old 06-14-2009, 08:59   #15 (permalink)
Member deceased !!
Mohsin Ali S's Avatar
Member: 390175
Thanks Meter: 19
Its true change betty light will be 10000000% solved tested by me today
The Following 3 Users Say Thank You to Mohsin Ali S For This Useful Post:
6120c light problem ahmedbarra Nokia Hardware & Hardware Repair 2 09-05-2010 15:11
nokia 6120c light problem m zubair Nokia Hardware & Hardware Repair 6 01-31-2010 14:05
6120c lights problem dmad cellular Nokia Hardware & Hardware Repair 2 01-05-2010 14:28
6120c lighting problem solution pls??? roney_nexus Nokia Hardware & Hardware Repair 3 09-09-2009 05:40
6120c light problem p.sekar Nokia Hardware & Hardware Repair 4 09-23-2008 17:32
Page generated in 0.40621 seconds with 9 queries
