Old 06-12-2009, 05:50   #1 (permalink)
Adil Mobiles's Avatar
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
6120c Not Charging.
Hello Friends,
I have a 6120c with not charging problem.
I have changed its battery but same condition.
where is fault?
plz share
Thanx in Advance.
The Following 2 Users Say Thank You to Adil Mobiles For This Useful Post:
Old 06-12-2009, 06:09   #2 (permalink)
^^^RAVI SOOD^^^'s Avatar
Member: 903492
Sonork: 1590666
Thanks Meter: 571
1st chack shortege in charging point... nd reply
The Following 2 Users Say Thank You to ^^^RAVI SOOD^^^ For This Useful Post:
Old 06-12-2009, 07:22   #3 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.try it..resalt post here.
The Following 4 Users Say Thank You to mahbubalfa For This Useful Post:
Old 06-12-2009, 07:27   #4 (permalink)
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
There is no shortage in Charging Points.
any idea?
The Following User Says Thank You to Adil Mobiles For This Useful Post:
Old 06-12-2009, 07:28   #5 (permalink)
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
Dear, wat i have to do after see this picture??
have to change these components ?
The Following 3 Users Say Thank You to Adil Mobiles For This Useful Post:
Old 06-12-2009, 07:39   #6 (permalink)
mizancoxr's Avatar
Member: 544628
Thanks Meter: 166
load good pm file with sx4
The Following User Says Thank You to mizancoxr For This Useful Post:
Old 06-12-2009, 08:38   #7 (permalink)
mahbubalfa's Avatar
Member: 1003058
Bro.chack this components..............
The Following User Says Thank You to mahbubalfa For This Useful Post:
Old 06-12-2009, 08:53   #8 (permalink)
Member: 769023
Sonork: lal
Thanks Meter: 4
6120c shows " not charging" on display
just remove a resistance behind the battery terminal and reply
The Following 4 Users Say Thank You to lal2636 For This Useful Post:
Old 06-12-2009, 09:13   #9 (permalink)
Member: 113283
Thanks Meter: 7
have you tried changing the charging block
jybx
Old 06-12-2009, 09:16   #10 (permalink)
Member: 113283
Thanks Meter: 7
have you changed the charging block
jybx
Old 03-13-2010, 23:44   #11 (permalink)
Member: 846933
just change betty ic 100000000000% sure
Old 03-14-2010, 09:32   #12 (permalink)
Mobile Marshel's Avatar
Member: 1144224
Thanks Meter: 55
just remove this component
The Following 3 Users Say Thank You to Mobile Marshel For This Useful Post:
Old 06-05-2010, 14:46   #13 (permalink)
Member: 1029665
Thanks Meter: 9
Hello Friends,
where is fault?
plz share
Thanx in Advance.
bro just remove small component behind the battery connector it will start charging I don't know how to upload images if you don't understand send me your email i will send you pic
The Following 3 Users Say Thank You to shahidanjum7 For This Useful Post:
Old 09-19-2010, 16:59   #14 (permalink)
Member: 1106514
Thanks Meter: 133
it's right ... just remove the competent behind the battery connector .
i just solved the same problem
it works 100000000000000000000%
The Following 2 Users Say Thank You to soulay For This Useful Post:
Old 02-14-2011, 10:34   #15 (permalink)
ericnite101's Avatar
Member: 450871
Sonork: 100.1592197
Thanks Meter: 121
Thanks bra it worked....
BR,
ERIC
pls help nokia 6120c not charging bassemzini Nokia Hardware & Hardware Repair 6 01-08-2011 06:28
pls help nokia 6120c not charging bassemzini Nokia Hardware & Hardware Repair 1 01-17-2009 20:56
pls help nokia 6120c not charging bassemzini Nokia Hardware & Hardware Repair 0 01-16-2009 10:49
6120c not charging adam621 Nokia Hardware & Hardware Repair 0 01-05-2009 20:13
need help 6120c not charging dhenz_y Nokia Hardware & Hardware Repair 1 04-21-2008 03:13
Page generated in 0.29428 seconds with 9 queries
