Old 05-17-2011, 12:54   #1 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
;;6120c very strange problem ;;
I have one 6120c its ear speaker not working
i did done many things den also same,
1.change speaker
2.trace track , and change filter , made jumper on filter
3.trace track through avilma, change avilma,
4.flashed with last version
5.removed R2105,R2104.
still same , i did changed avilma 3 or 4 times and took from working set also
masters am waiting for solution..
br,
WAJID
Old 05-17-2011, 14:26   #2 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,687
only ear piece not working or mic also?
check casing holes may b some dust inside of that holes
is the reading normal at points like a normal set?
if yes.....so u can make jumpers direct at earpiece from there
check ur jumper at L2100 u made them right?
post reply .......
Old 05-17-2011, 14:34   #3 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
post reply .......
thanks for ur kind reply ..
everything working rest earpiece ,
brother if casing have no holes also can hear little bit
but its not working ..
i think u mean about Output Ohmz??
if yes its like working set , no different.
i think no need jumper this all track are ok na
den y?
Old 05-17-2011, 14:43   #4 (permalink)
Member: 328187
Thanks Meter: 1,687
very amazing fault
but please make jumper at speaker direct from board and check
what about mic ?
Old 05-17-2011, 14:52   #5 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
very amazing fault
what about mic ?
i already wrote above mic and ringer are working!!
and i dnt think its speaker contact problem,
speaker contacts are ok,
Old 05-17-2011, 15:04   #6 (permalink)
Member: 328187
Thanks Meter: 1,687
i think its audio frequency problem
witch band u r using? 850 ...900 1800/1900 ?
use an other band by an other sim and check
imei start from 35.........0r 01........?
Old 05-17-2011, 15:31   #7 (permalink)
Member: 328187
Thanks Meter: 1,687
if u can hear call at loud speaker then its not frequency problem
rehot rapido and check.......
u can take help from level 4 schematic
Old 05-17-2011, 15:56   #8 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
its not ear speaker related !
other member may b confused !!
let me check rapido,bt shall i knw any1 faced the problem?
Old 05-18-2011, 06:35   #9 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
@ktkwajid
FINALY THIS CAUSE GO TO BAD RAPIDO BECOZ AUDIO DATA CONTROLLED BY RAPIDO
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 05-18-2011, 08:53   #10 (permalink)
neilthirumuttam's Avatar
Member: 15903
Sonork: 100.1583162
Thanks Meter: 1,046
let me ask one thing related this ?
is the set perform ear speaker in blue tooth headset or normal headset?
please check and say, just to know, because me personally not faced this
case
Old 05-18-2011, 10:44   #11 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
case
blue tooth headset and normal headset are working fine!!
wil reball rapido den wil post result later !
br,
WAJID
Old 05-18-2011, 12:11   #12 (permalink)
Member: 15903
Sonork: 100.1583162
Thanks Meter: 1,046
so let us assume that there is no error in the process of de-modulation, de-coding and
audio data processing .
Am i right ?
if so, where is the error
most print and parts u have checked .
now there we need some electronics repairing tools like signal generator , CRO etc
but they are not commonly used in gsm
high investment needed
rate of return !!!!
so what we can do ?
The Following User Says Thank You to neilthirumuttam For This Useful Post:
Old 05-18-2011, 12:35   #13 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
Am i right ?
rate of return !!!!
so what we can do ?
Am i right ?
yes, sure i agree with this ,
Old 05-23-2011, 19:16   #14 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
its done after re-balling rapido !!
The Following 2 Users Say Thank You to WAJID PNR For This Useful Post:
Old 05-02-2012, 19:04   #15 (permalink)
Member: 1450150
i have 6120c phone ; its headphon way water damage .plz give me any headphon track...............
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 19:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.25582 seconds with 9 queries
