Old 12-03-2011, 16:03   #1 (permalink)
Member: 1276771
Thanks Meter: 30
6120c water damage short
6120c water damage
i clean the board and give heat to ic
the phone is in dead position
with dc power supply the current is 0.16 without pressing the power button it shows 0.16 current
it is short
any expert member have the best solution for this phone????
The Following User Says Thank You to javeed_aminy For This Useful Post:
Old 12-03-2011, 16:17   #2 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,212
remove bluetooth ic and chk
The Following User Says Thank You to HUM For This Useful Post:
Old 12-03-2011, 17:09   #3 (permalink)
Member: 1276771
Thanks Meter: 30
can u upload the diagram ??/
Old 12-03-2011, 20:48   #4 (permalink)
snmobilecenter's Avatar
Member: 983663
Sonork: 100.1623270
Thanks Meter: 513
1st a fall feel which component gets hot?
if any component doesn't hot....
might be cuse
headset ic
memory ic
bluetooth ic
camera
Fm ic
Pfo
display ic
key pad ic
@ last beety
@ avilma
WORK HARD WITH WATER DAMAGE SET
AND TRY TO FIND FULT BY YOURSELF
THEN POST ONLY SUCCESS WORK
The Following User Says Thank You to snmobilecenter For This Useful Post:
Old 12-03-2011, 22:20   #5 (permalink)
Member: 1628887
Sonork: 100.1648746
Thanks Meter: 69
Bro .....pls change power ic....may be get answer.......your mobile water damage,so no have parfect solution..........pls tr.thanks
The Following User Says Thank You to rakib akand For This Useful Post:
Old 12-03-2011, 22:30   #6 (permalink)
Member: 983663
Sonork: 100.1623270
Thanks Meter: 513
wich one power ic in 6120c ?
Old 12-03-2011, 22:55   #7 (permalink)
Member: 1646875
Thanks Meter: 16
its not Avilama like work power ic br?
The Following User Says Thank You to samip2066 For This Useful Post:
Old 12-04-2011, 12:49   #8 (permalink)
Member: 1276771
Thanks Meter: 30
cant find the shortage ??that from where it is short???
the easy way to find short place of the board??
Old 12-04-2011, 13:30   #9 (permalink)
Wites OM Tesla's Avatar
Member: 1017374
Thanks Meter: 2,545
Bro give externally power to phone or use a charged battery,check with you lips
where is heating some component where is heating there is short,tested on a bunch of phones.
Old 12-04-2011, 19:08   #10 (permalink)
Member: 1628887
Sonork: 100.1648746
Thanks Meter: 69
Post
bro
you know this ic
Old 12-04-2011, 20:31   #11 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,212
this one is avilma power ic
6110 droped in water...... mrENigma Nokia Hardware & Hardware Repair 5 04-05-2004 04:35
water damaged 5110 gsmxc Nokia Hardware & Hardware Repair 5 10-18-2001 17:15
nokia short and full flash files bulent150652 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 04-15-2001 03:02
3210 *water damaged* no reception pks Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 03-28-2001 12:09
How to open 3210 without damaging? Kane Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-06-2000 17:41
Page generated in 0.49366 seconds with 9 queries
