02-11-2004, 21:45 | #1 (permalink) |
Freak Poster Join Date: Jul 2002 Location: Europe Age: 47
Member: 13827 Status: Offline Thanks Meter: 16 | 6210 after change cobba Have problem : after change cobba, power onnly led and black screen for a moment and beeping sound from speaker. Without cobba shows "contact service" like normal ! Change 3 cobbas still the same,change hagar,ccont....still the same NOT water damage! please any help |
02-12-2004, 15:18 | #2 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Really strange but it could be not IC problem it may be a shorted Capacitor pushing the cobba to get crazy oscillating !! Also the capacitors of the smoothening of the voltages if not working gives instability and strays wich may leads to oscillation too. |
02-12-2004, 18:46 | #3 (permalink) |
Freak Poster Join Date: Nov 2003 Age: 45
Member: 43545 Status: Offline Thanks Meter: 7 | @ tgsm I thinks first of all to change C450 ,C451,C452 COMPONENTS. And If the problem is not solve THEN TRY TO REMOVE VOLUME BUTTONS and CHECK THE SHORTING ON VOL. BuTTONS, if there is any shorting then remove .........DEAR BEST OF LUCK //Tanmay// |
02-12-2004, 19:04 | #4 (permalink) |
Freak Poster Join Date: Feb 2002 Location: I am outside your house, I am armed Age: 56
Member: 9698 Status: Offline Thanks Meter: 0 | 1. Look for components missing around cobba where you worked. 2. Some of the green paint covering the pcb under the cobba is gone and now the balls isn't a ball when you put it on again. (The solder runs onto the tracks) 3. If this is the case no way to repair most of the time. |
6210 restarts after changing cobba - Help | noone0 | Nokia Hardware & Hardware Repair | 10 | 05-11-2003 18:45 |
6210 no pwer after changing LEDs | litolang | Nokia Hardware & Hardware Repair | 8 | 02-21-2003 07:32 |
6210 dead after changed connector !! | douda | Nokia Hardware & Hardware Repair | 0 | 06-21-2002 23:27 |
3310 "simcard not accepted" after changed the cobba. | HuyGSM | Nokia Hardware & Hardware Repair | 6 | 10-31-2001 13:52 |
6210 doesnīr charge after changing ledīs | RIVER | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-18-2001 09:37 |
