Old 11-05-2002, 08:31   #1 (permalink)
Member: 12869
Thanks Meter: 3
6210 cannot make a call
Hi,
I have a 6210 that has full signal but everytime I try to call it drops signal and picks up signal afterwards, what could be the problem. Somebody, please.
Old 11-21-2002, 20:05   #2 (permalink)
DMD
DMD's Avatar
Member: 12660
Thanks Meter: 7
Lightbulb 6210
Hi Black-Axe
Have you tried changing the P.A and antenna switch?
often after desoldering the P.A you can see that its cracked
Later D.
Old 11-22-2002, 06:48   #3 (permalink)
Member: 12869
Thanks Meter: 3
Thanks alot for your reply DMD, but after I took off the PA and antenna switch the phone died, which was very strange, I put it back and checked if I moved any chips while taking off PA, but I didn't and phone is dead. I'll keep checking.
Thanks,
Black-Axe
Old 11-22-2002, 07:10   #4 (permalink)
mujie's Avatar
Member: 8304
Thanks Meter: 362
Maybe you melted power switch,check for play in it.Or plug a charger in the phone and see if it charges.
Old 12-04-2002, 05:28   #5 (permalink)
Member: 12869
Thanks Meter: 3
My phone is back on again but the problem now is after change pa it still has full signal but when I call out signal drops and when call ends, signal comes back up again.
Old 12-05-2002, 10:16   #6 (permalink)
Member: 12158
have you tried bridging the ariel switch?
this sometimes works
fatz
Old 12-05-2002, 10:30   #7 (permalink)
Member: 12869
Thanks Meter: 3
Thanks, I'll try that
Old 12-05-2002, 10:34   #8 (permalink)
Member: 12158
works alot of the time for me
in fact only last night i did this with success
fatz
Old 12-05-2002, 23:03   #9 (permalink)
Member: 18330
chinge ic cobba and tray it wil send
Old 12-07-2002, 00:48   #10 (permalink)
george gsm's Avatar
Member: 14200
Sonork: Sonork id
Thanks Meter: 117
black axe,
look like a hagar problem. reballs or change it if need.
regards,
geo
Old 12-07-2002, 14:36   #11 (permalink)
Member: 12869
Thanks Meter: 3
Thanks alot people for you replies, I really appreciate.
I'll try and change hagar and cobba but phone is very weird, 'cos I just changed PA again and signal pick up and drop after 5 seconds, so I don't think its PA problem 'cos its a new PA.
When I change hagar and cobba, I'll let you know.
After flashing 3200 it cannot make any call or answer any call. smartfone Griffin 5 11-24-2005 02:45
Phone cannot make/receive calls after unlock (with code) phillis_c Nokia Digital Core Technology 4 ( DCT-4 ) 5 12-06-2003 13:50
cannot make a call in c35...screen is displaying an exclamation mark sidharthaharish Siemens Hardware Repair Area 8 12-17-2001 21:34
Hi! I have a problem with sagem rc815 !It cannot make a call 112! zdob Infineon C16X M51 & ARM7 M52 BASED 0 04-17-2001 17:06
Page generated in 0.20336 seconds with 9 queries
