Old 12-09-2003, 04:38   #1 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
6210 "no network found" after 3 sec.
I have one 6210 and ,when I try to search for networks , it gives "no network found" after 3 seconds .
Any suggestion ??
Thx !
Old 12-09-2003, 08:49   #2 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 116
Most probably Rx section faulty!! check Diplexor, Antenna, Hagar
WBR
Syed
Old 09-02-2004, 17:30   #3 (permalink)
Member: 30205
Thanks Meter: 4
must of the time in this situation check your antenna & cobba first
Old 09-03-2004, 23:52   #4 (permalink)
Member: 73571
Thanks Meter: 2
i thinck your's ant sw is brocken try to replace'it if the pb persist try to reball the CCONT
Old 09-29-2004, 15:12   #5 (permalink)
vio
Member: 77011
first you must rehot , ( resolder ) or change cobba
Old 10-01-2004, 18:02   #6 (permalink)
garmani's Avatar
Member: 43758
In most cases is bad PA (power amplifier) .
Old 11-05-2004, 22:53   #7 (permalink)
mohammad2004's Avatar
Member: 71144
Thanks Meter: 12
full org flash
repalce pa-swich antenn
check the cobba ic and hagar ic
Old 11-08-2004, 22:25   #8 (permalink)
Member: 80757
Verify if you are on Automatically Network Check... If it's on manual it could explain why that doesn't work...
Old 11-12-2004, 20:29   #9 (permalink)
Crazy Poster
Member: 90958
Thanks Meter: 11
You must Change PA
regards
Old 11-12-2004, 23:18   #10 (permalink)
Ciubaka's Avatar
Member: 42304
Thanks Meter: 12
Originally Posted by data mobile
You must Change PA
regards
It says no network so you sdont have to change PA !
try to change cobba
Nokia 3100/3120 "no network found" problem nakshatra Nokia Hardware & Hardware Repair 5 04-10-2010 08:31
Nokia 6020 "No Network Found" Ankit Verma Nokia Hardware & Hardware Repair 8 03-14-2009 20:35
Nokia 6020 "No Network Found" Ankit Verma Nokia Hardware & Hardware Repair 13 10-08-2008 10:29
Nokia 6020 "No Network Found" Ankit Verma Nokia Hardware & Hardware Repair 1 03-16-2008 07:19
Nokia 8800 sirocco gold "no network found" taisfus Nokia Hardware & Hardware Repair 0 12-23-2007 05:53
Page generated in 0.18307 seconds with 10 queries
