12-31-2005, 14:05 | #4 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | u can find very easy with no scheme or diagram, just multi meter: turn your meter into a diode (continuity) tester, then make test of the pad you have to ground. if it beeps then you know missing pad must be +VCC. if it dont beep then your missing pad is ground so just make jumper to any ground point. if you had VCC pad missing, just find the point on the very small components by the switch that is ~3.8V and make jumper from there to your switch. use some epoxy resin (very small dab) to hold the switch to the board, as it will be very less strong with one leg missing. |
12-31-2005, 19:40 | #5 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: T.E.T.O.U.A.N
Member: 190492 Status: Offline Sonork: 100.01010100 Thanks Meter: 190 | 6210 On Off Switch Quote:
01-01-2006, 11:41 | #6 (permalink) | |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Quote:
01-01-2006, 11:48 | #7 (permalink) | |
This is a propper way to build a ( BOOUM ) not power-Sw connection !!!! , U'r directing the guy to build a short leads Sw ( Ground + Vcc ) ? !!!! | |
3200 power switch, new switch? | sjakie | Nokia Hardware & Hardware Repair | 5 | 02-14-2006 22:58 |
need 6210 power switch ways urgently | classic mobiles | Nokia Hardware & Hardware Repair | 2 | 01-19-2006 23:03 |
6210 power switch | [Rod] | Nokia Hardware & Hardware Repair | 0 | 03-08-2005 20:36 |
Nokia 6210 Power switch | LORD_SHAH | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 10-28-2004 19:15 |
6210 , power switch advice needed | N/East Unlocker | Nokia Hardware & Hardware Repair | 5 | 08-13-2003 22:00 |
