Old 07-24-2002, 02:15   #1 (permalink)
Member: 12571
Red face 6210 signal loss
whenever i receive or make calls my signal drops or i get cut off!!!
tried jumper on antenna, but does not work!!
what is next?
Old 07-24-2002, 08:18   #2 (permalink)
Member: 7586
Thanks Meter: 11
try to rehot cobba with enough flux.
b.r
Pali
Old 07-26-2002, 07:56   #3 (permalink)
DMD
DMD's Avatar
Member: 12660
Thanks Meter: 7
Talking 6210 signal loss repair
There is a Nokia bulletin floating around the net telling you how to fix the signal problems look for it!
1. The antenna switch ( the solder connecting the metal can cracks they recomend replacing.
2. If you make a call and twist the phone if the voice goes away then you have dry joints on the cobba
but I reckon the P.A could also be shot, Hope this helps D.
Old 07-26-2002, 13:16   #4 (permalink)
doubleB's Avatar
Member: 13341
try palis idea ...I tested it myself....
Old 07-27-2002, 20:59   #5 (permalink)
Member: 12571
Talking Thanks
Thanx 4 all ya help!!!!
will try finding dry joints, might be problem.
As all other solutions don't help!!!
But keep it coming, I need all the tips out there
Thanx
Old 07-30-2002, 15:54   #6 (permalink)
Member: 12443
try reheating the p.a., antenna switch, hagar,cobba. put some flux on it. let it cool down for a few minutes before restarting your phone
Old 07-30-2002, 16:07   #7 (permalink)
GSM Coolhawk's Avatar
Member: 7751
Thanks Meter: 74
@DMD
The Nokia Bullentin you are talking about is located at Schwantz homepage, actually he have 2 different solutions there.
Schwantz homepage
Regards
Old 07-30-2002, 16:33   #8 (permalink)
Member: 7751
Thanks Meter: 74
Hi
Sorry I posted the wropng link to Schwantz
Here the correct one is
http://kickme.to/gsmschwantz
Regards
Old 07-30-2002, 21:29   #9 (permalink)
Member: 1060
Thanks Meter: 9
Re: 6210 signal loss
feverdj,
System you are useing is 900 or 1800 ?
can you enable net moniter, and run at test 01
and see, what is CH , what RX LEV, ?
when your phone stand by, every thing (RX) is ok ?
Willy
what is next?
Old 08-01-2002, 04:16   #10 (permalink)
Member: 12571
willy, i will try your approach to problem & let u know the outcome soon!!!!!
thanx & keep it coming...
great to have such a good response - thanx again
fever
Old 08-01-2002, 05:25   #11 (permalink)
Member: 1060
Thanks Meter: 9
fever,
thank
look like your phone been keep on switch 900 -> 1800 -> 900.....
and TCXO 26Mhz AFC control not good by COBBA , or TX I/P .........
i need more info, to know what is your phone's problem ..
B.R.
Willy
fever
Old 08-02-2002, 03:00   #12 (permalink)
george gsm's Avatar
Member: 14200
Thanks Meter: 91
hi,
in this case i tnink must change:
1..upgrade soft
2. the duplexor filter(antena swich)
3. rf
4. resoldering (hot air with flux or rosin disolved in isopropilc alcohool) hagar, ccont, cobba.
if don't work tell me,
geo
Old 08-03-2002, 04:50   #13 (permalink)
Member: 12571
dual band network 900/1800
Old 08-03-2002, 09:11   #14 (permalink)
Member: 1060
Thanks Meter: 9
Fever DJ,
Please try to use ROLIS SW V1.7 to enable Net moniter,
go to test 01.
download how to use net moniter for if you do not have RF tester!
http://www.nobbi.com/download/nmmanual.pdf
look at CH , when you make a call, is phone keep change CH by show "Hxxx" ,
then check xxx number !
CH 1-124 is use for GSM 900 !
and check when you make a call ( you can see TXpwr *xx), then how is your RX-L !
Willy
Old 08-12-2002, 20:58   #15 (permalink)
Member: 12571
Hi Willy
Ch - 42 (jumps around) goes to 26 when signal drops
RxL - 68
Pwr - *9
Hope This Helps!!1
5110 signal loss nightxyz Nokia Hardware & Hardware Repair 1 08-13-2002 10:45
6150 signal loss CiprianGSM Nokia Hardware & Hardware Repair 0 07-31-2002 08:55
solution for signal loss in 3310....... .:*CHENNAI GSM*:. Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 06-20-2002 02:34
6210 Signal Loss Repair solution schwantz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 04-16-2002 08:21
Page generated in 0.43619 seconds with 8 queries
