03-26-2003, 21:28 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: slovenia Age: 48
Member: 18028 Status: Offline Thanks Meter: 20 | 6210 strange what can be wrong? on wt also ok |
03-27-2003, 08:47 | #2 (permalink) |
Freak Poster Join Date: Jul 2002 Location: Croatia Age: 49
Member: 14004 Status: Offline Thanks Meter: 6 | Clean mic contacts in bottom connector, resolder bottom connector. Dirty contacts on the bottom connector can cause mic problems. Then try to rehot / reball / change COBBA. |
03-29-2003, 11:59 | #4 (permalink) |
Member: 18028 Status: Offline Thanks Meter: 20 | i dont change hagar it was PA it is not only one with this simptoms when you upgrade version then come this simptomps even than if you put original flash back not good |
09-18-2003, 10:22 | #5 (permalink) |
Freak Poster Join Date: Mar 2001 Location: Czech Republic
Member: 3714 Status: Offline Thanks Meter: 6 | Hello i have many many these phones - i mean 6210 with these symptoms. when i call, i hear everything OK but the other side sometimes not, it seems that mic is not functional for about 1sec many times throught one the call... I tryed change mic and check line to cobba and change cobba for new one but it didnt help! any idea? Platy |
09-20-2003, 21:07 | #7 (permalink) |
Freak Poster Join Date: May 2001 Location: Europe Age: 44
Member: 4533 Status: Offline Thanks Meter: 13 | Me too experienced that problem with 6210, however it shouldn`t be caused by updating the software i think. If it is software failure then it would be easily repairable. I had two 6210 in last 3 weeks and both had the same problem - the person I was talking to sometimes heared cca. 1-2 seconds interruptions in speech. Since it looks quite usual failure with 6210, I doubt microphone is the cause. Please anyone has(and someone surely has) an useful info on that problem mail to gsm-forum. Thanx in advance |
09-20-2003, 21:12 | #8 (permalink) |
09-21-2003, 13:31 | #10 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Well first of all to eleminate each problem 1slly,use hand free kit to be sure it is not the internal mic. If you found it the internal Mic problem,and as u change the cobba try to change the Bias curent transistor V231 and check its path. Withe new cobba and the same problem in the internal + external Mics, that means that it is not an audio problem, so we can turn to the RF section. |
Nokia 3330 and 6210 strange rf problem | tob | Nokia Hardware & Hardware Repair | 3 | 03-12-2004 20:35 |
6210 strange problem | GSMWolf | Nokia Hardware & Hardware Repair | 2 | 05-15-2003 23:34 |
6210 strange problem | kenwood | Nokia Hardware & Hardware Repair | 0 | 03-20-2003 17:13 |
6210 strange problem | tkerek | Nokia Hardware & Hardware Repair | 2 | 10-25-2002 16:42 |
6210 strange problem | Gaborrr | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-19-2002 03:10 |
