Old 09-03-2003, 21:34   #1 (permalink)
gibso's Avatar
Member: 25150
Thanks Meter: 8
6210 switches on with battery
hello all' pls help me out of this one.
i have a 6210 that comes on as soon as i insert the battery,
also it trips of, i removed the power switch thinkin its bridging inside but no work.
pls help.
\thnx,
gibso.
Old 09-03-2003, 21:40   #2 (permalink)
Member: 17193
Thanks Meter: 16
Try reballing/changing ccont, probably You've got some short circuits under it
Old 09-03-2003, 22:38   #3 (permalink)
GSM Coolhawk's Avatar
Member: 7751
Thanks Meter: 74
@gibso
This problem normally occurs when the rubber presses the swicth. Have you tried to put the battery on the phone without the cover, only board and screen ??
If it does not power on, you've found your problem.
Regards
e6 switched on with charger only & Shows Red Line On Battery Symbol ***___LAMA-GSM_ Motorola Hardware Repair 1 06-20-2008 05:26
e6 switched on with charger only & Shows Red Line On Battery Symbol ***___LAMA-GSM_ Smart-Clip 1 06-16-2008 16:20
>>W200 Automaticall Switch on when battery inserted<< SAYCOMP Sony Ericsson Hardware Repair 1 02-13-2008 06:16
c65 cant on with battery only with power supply GOODNESS Siemens Hardware Repair Area 0 08-28-2006 14:06
6210 switch on after flash read?? reo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 08-11-2001 17:31
Page generated in 0.11291 seconds with 10 queries
