Old 08-22-2007, 05:59   #1 (permalink)
Member: 518286
Thanks Meter: 2
nokia 1600 net work problem
Dear friend
i have recive nokia 1600 handset net work problem
plz give me the soln of net work problem
The Following User Says Thank You to anil&hemant For This Useful Post:
Old 08-22-2007, 20:59   #2 (permalink)
puneet14884's Avatar
Member: 399779
Thanks Meter: 125
Arrow
Originally Posted by anil&hemant View Post
Dear friend
PLS post some details.....rehot & reflow network section.....write pm...........post result
regards
PUNEET14884
The Following User Says Thank You to puneet14884 For This Useful Post:
Old 08-22-2007, 21:26   #3 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
Common problem, common solution change the PA ic and check the result....
Old 08-22-2007, 21:29   #4 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
i think its filters problem, change or short? post result!
Old 08-23-2007, 05:50   #5 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
Dear brother,
First re-set the phone setting if not
then check the antena connection if not
Then write the good PM if not
do it and post the results
Dear friend
Old 08-23-2007, 08:27   #6 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
if u try all this and the problem still same,try 2 replace the RF ic and the final solution is replace Uem ic!!! Good luck
Old 05-28-2008, 15:46   #7 (permalink)
Member: 621454
Thanks Meter: 30
Dear friend
please replace rf ic or write pm file with full erase
Old 05-28-2008, 16:40   #8 (permalink)
Member: 706712
Thanks Meter: 2
Dear friend nokia n70 cmt loder fail
Old 05-28-2008, 21:58   #9 (permalink)
Member: 675717
Thanks Meter: 125
I have same problem.I changed PA,RF same problem.Please help me.
Old 06-16-2008, 08:31   #10 (permalink)
sujan1050's Avatar
Member: 449518
Thanks Meter: 585
same problem i will write the full pm.......................but same problem bro
Old 06-19-2008, 10:15   #11 (permalink)
Member: 621454
Thanks Meter: 30
Dear friend
flash the phone &then writ pm file .if not working then change rf ic
Old 06-19-2008, 10:17   #12 (permalink)
Member: 621454
Thanks Meter: 30
change rf ic it will be solve your problem
The Following User Says Thank You to sunil8888 For This Useful Post:
Old 06-19-2008, 11:58   #13 (permalink)
Amr Fouad's Avatar
Member: 613706
Sonork: 12345
Thanks Meter: 13
please read (vip)
i have n95 it is work good only i want flash it arabic flash file on jaf says (cmt boot loader fail) what the solution?
B R
Gold
Old 06-19-2008, 14:51   #14 (permalink)
Member: 728720
i think this problem from PF pls change PF
Old 06-20-2008, 16:22   #15 (permalink)
gsmawan's Avatar
Member: 578828
Thanks Meter: 88
1600
if ur phene signal not recieve then check ur antina point and switch then rx filter.If ur phone signal come then go check ur pa and tx section...
nokia 6300 net work problem m zubair Nokia Hardware & Hardware Repair 7 12-22-2010 16:58
sir nokia 7210c rm-436 net work problem plz...help...... Wasim007 Nokia Base Band 5 ( BB-5 ) 1 10-28-2010 22:57
How to solve nokia 7210c rm-436 net work problem by ub Wasim007 Universalbox 2 12-31-2009 11:58
nokia 1100 net work problem Raa_z Nokia Hardware & Hardware Repair 8 06-20-2008 06:55
Nokia 2300 Net Work Problem de brain box Nokia Hardware & Hardware Repair 0 11-22-2006 12:30
Page generated in 0.23107 seconds with 10 queries
