Old 11-08-2005, 17:56   #1 (permalink)
Member: 7267
Question 6230 Bleu thoot
I have a Q
with 6230 wen the bleuthoot don't work
somtimes rewriting helps
somtimes TQ
but then if it stil doens't work i trey'd bleuthoot module but it stil the same after wards
wat can i try ?
its like this if you try to put on the bleuthoot you see back in the menu and its back on off ????
Old 11-09-2005, 00:45   #2 (permalink)
GSM Coolhawk's Avatar
Member: 7751
Thanks Meter: 74
@GSMTEK
Most properly you have a faulty Bluetooth module, you'll need to change it or reflow/reball it. Works for me everytime if reflashing it does not help.
Regards
Old 11-09-2005, 08:44   #3 (permalink)
Member: 7267
Originally Posted by GSM Coolhawk
@GSMTEK
Regards
**** he I tryed that, I'll try it again or does somone have an other ID ?
Old 11-09-2005, 08:45   #4 (permalink)
Member: 7267
of topic got to stop the "bad words"
Old 11-25-2005, 10:38   #5 (permalink)
Member: 7267
I found it seems there are 2 bt versions depending on the hw version and defrint component around it depending witch bt chip so that was the problem
1st rw if stil nok
replace with corect bt chip depending on hw version
23 Feb 2008: Bleu-151x, Bleu-245x flash read/write supported InfinitySupport Infinity-Box 45 02-10-2009 15:27
01/05/08 : ET-BoX v1.65 Released - Here is the BLEU DAY.. Added Bleu 145x 151x & 245x nonu_don ET-BoX 47 11-02-2008 22:06
@ infinity -Bleu 245x freeze only on BLEU Screen???? vikramb1 Infinity-Box 0 09-11-2008 19:34
BLEU 145x show only bleu Sloution for all Enjoy all Member !!!! rekha1255 Infinity-Box 2 08-14-2008 13:02
Page generated in 0.26874 seconds with 8 queries
