Old 06-20-2006, 16:33   #1 (permalink)
caddisfly's Avatar
Member: 158648
Thanks Meter: 3
6230 bluetooth ic
hi friends
does anybody know if 6230 and 6680 bluetooth ic the same?
Old 06-20-2006, 22:22   #2 (permalink)
Registered User
Member: 143939
Thanks Meter: 264
Hi I think it's the same
Old 06-21-2006, 10:24   #3 (permalink)
caddisfly's Avatar
Member: 158648
Thanks Meter: 3
6230 bluetooth ic
hi friend
i need a solid answer...thanx for your reply,but your answer is not positive
Old 06-21-2006, 11:07   #4 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
@ ogre,
this may help you ?
6080 blue tooth ic : BC313143A-11-RK-E4
6230 blue tooth ic : BC213143A-17-RK-E4
at schematic all pin look like same . about bga size. no idea.
wbr
Old 06-22-2006, 07:40   #5 (permalink)
caddisfly's Avatar
Member: 158648
Thanks Meter: 3
6230bluetooth ic
Originally Posted by baraka42
@ ogre,
this may help you ?
wbr
hi friend
thank you will try to change and post result
Old 06-22-2006, 07:45   #6 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
@ ogre,
you wrote here.
hi friend
is there bga size is same ?
wbr
Old 06-22-2006, 20:44   #7 (permalink)
Member: 115570
Thanks Meter: 13
is the same CSR Bluetooth device (also used in some USB Bluetooth sticks)
in waterdamaged phones with bluetooth error, the fault is not located at this IC, so it is located at the PowerIC for bluetooth
6230 keypad ic track missing mujburbenz Nokia Hardware & Hardware Repair 1 01-07-2007 13:56
Nokia 6230 Light-IC (N300) TeddyBier Nokia Hardware & Hardware Repair 3 08-11-2006 09:23
Can I use 6230 keypad Ic in 6680? MaRiN Nokia Hardware & Hardware Repair 0 02-13-2006 17:15
6230 ram ic.... asteraky Nokia Hardware & Hardware Repair 0 05-16-2005 21:03
6230 Bluetooth problems when transferring mp3s to other 6230s Burnt Cobba Nokia Digital Core Technology 4 ( DCT-4 ) 0 08-30-2004 21:04
Page generated in 0.16631 seconds with 10 queries
