02-23-2007, 11:28 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: POLAND
Member: 27761 Status: Offline Thanks Meter: 55 | 6230: help me to find damage see loog from JAF, look here --> i have 6230, phone don't power on, under jaf only blinks several times of off. i found during flashing that NAND chip FAILED do i replace to new NAND (D450) but still phone don't poweron see logs first i CHK, and i think all is OK: Getting MCU ID MCU ID: 0x1052 FLASH ID0: EC00F822 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC003900 -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Checking RAM for ALGO... Algo is ready... Done! Phone Restarted... second, flashing still nand IC can't be formated. i put new flash(nand D450) ans still same problem. FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.500 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50a CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_a ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.500 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50b CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_b ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,French,Polish,Romanian,Hungarian MCU: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.500 Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.3B.00 -> Revision: 0007 Boot size is 0x2350 Boot is ready... FLASH ID0: EC00F822 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC003900 -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.3B.00 -> Revision: 0007 Loader size is 0x83E8; Loader chk: c0 Loader is ready... P-key nokia module version 01.00 MSID: 84ACF15C2B687964F045189CED MSID decoded: B03FBAE900422664A9000000 FAID: AFFD199C76ABB813432CDE4F Operation took 0 minutes 18 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 007FFFFF... Erasing area: 00800000 - 0093FFFF... Erasing area: 00B60000 - 00FEFFFF... Operation took 2 minutes 14 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 51 seconds... Restarting MCU... NAND Format FAILED!!! CNT: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_b Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.3B.00 -> Revision: 0007 Boot size is 0x2350 Boot is ready... FLASH ID0: EC00F822 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC003900 -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.3B.00 -> Revision: 0007 Loader size is 0x83E8; Loader chk: c0 Loader is ready... P-key nokia module version 01.00 MSID: 845D6C1CA7A796F4E4D82CC39B MSID decoded: 3E4EBAE900422664A9000000 FAID: 2D32D3B9FB03752E10A19374 Operation took 0 minutes 17 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 00940000 - 00B3FFFF... Operation took 0 minutes 19 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 9 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Extracting Content Pack... Error setting local mode... CP Extract Failed! PPM: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50b Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.3B.00 -> Revision: 0007 Boot size is 0x2350 Boot is ready... FLASH ID0: EC00F822 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC003900 -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.3B.00 -> Revision: 0007 Loader size is 0x83E8; Loader chk: c0 Loader is ready... P-key nokia module version 01.00 MSID: 84C8687A28CFC49CBB930A1FBE MSID decoded: 3E4EBAE900422664AA000000 FAID: D184437E6549538CCAC5829D Operation took 0 minutes 18 seconds... Erasing PPM... Found 1 interval(s) to erase Erasing area: 00940000 - 00B3FFFF... Operation took 0 minutes 19 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 9 seconds... Restarting MCU... Flashing Done! Operation took 6 minutes 4 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! what i have to change to alive that 6230? could it be UEM/UPP error ? |
Help me to find the link to download RH-29 for N-Gage QD | spy007dvt | WD2 & APE (Symbian Phones) | 2 | 06-03-2006 04:55 |
Who can send me or help me to find flash file for GD70 v22A or similar??? | starpho | Panasonic | 0 | 10-11-2001 03:10 |
Who can send me or help me to find flash file for GD70 v22A or similar??? | starpho | Panasonic | 0 | 10-05-2001 02:38 |
Does somebody want to help me to find service manuals for mobile phones(free) | starpho | Old Ericsson Phones & Sony Phones | 3 | 03-11-2001 18:29 |
