06-28-2009, 15:09 | #1 (permalink) |
Junior Member Join Date: Mar 2008
Member: 729533 Status: Offline Sonork: 111111 Thanks Meter: 5 | 6230 i flash problem before flash its info FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 03.80 31-Mar-06 RM-72 GSM P1.1 (c) NMP. PCI version: UEM version: 400 UPP version: 4178 RFIC version: p 10ff11ff0205 DSP version: p B0446T_05w14 LCD version: UNKNOWN PPM version: BT MCM version: 0382 ADSP SW version: TIKU_PB_04w47_06_w01 Content Pack version: V 03.80 31-Mar-06 RM72_73_- GSM P1.1 (c) NMP. Production serial number: Product code: Module code: Basic production code: Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 357082003408710 IMEI spare to net: 3A 75 80 02 30 04 78 01 IMEI SV to net: 33 75 80 02 30 04 78 21 F1 Master Code: 0536226375 Phone type: RM-72, Software version: 03.80, Language Pack: not available User code: 12345 Block 1: Lock 1: CLOSED -> Lock Data: 00101F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-72.ini Saved INI not found, loading INI list... after flash its info Phone Type: FILES SET FOR FLASHING: MCU Flash file: D:\New Folder\Products\rm-72\rm72_73_11003.800 PPM Flash file: D:\New Folder\Products\rm-72\rm72_73_110M_03.80o CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,Italian,Spanish,Turkish Phone Type: FILES SET FOR FLASHING: MCU Flash file: D:\New Folder\Products\rm-72\rm72_73_11003.800 PPM Flash file: D:\New Folder\Products\rm-72\rm72_73_110M_03.80o CNT Flash file: D:\New Folder\Products\rm-72\rm72_73_110E_03.80.ucp_mobistar_be3 ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,Italian,Spanish,Turkish MCU: D:\New Folder\Products\rm-72\rm72_73_11003.800 Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 003500EC <=> SAMSUNG (SEC) -> K5E5657ACB Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x84A0; Loader chk: 34 Loader is ready... P-key nokia module version 01.02 MSID: 849C9843D75E2C01EB483B9155 MSID decoded: FE4CBAE900028160A8000000 FAID: F0499616913F1C21FBF9491A Operation took 0 minutes 19 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 009FFFFF... Erasing area: 00A00000 - 00B3FFFF... Erasing area: 00B60000 - 00FAFFFF... Operation took 2 minutes 49 seconds... Writing... Perm. Data Restore OK Operation took 1 minutes 0 seconds... Restarting MCU... CNT: D:\New Folder\Products\rm-72\rm72_73_110E_03.80.ucp_mobistar_be3 Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 003500EC <=> SAMSUNG (SEC) -> K5E5657ACB Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_essr.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x9858; Loader chk: cb Loader is ready... Operation took 0 minutes 18 seconds... Erasing Content Pack... Mass Memory Device Detected... MM Bus Configured... Formating MM...Format OK Mass Memory Opened... Mass Memory Erased... Operation took 0 minutes 14 seconds... Writing... Operation took 0 minutes 35 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Extracting Content Pack... Running: (c) Nokia File Server CP Extract Failed! PPM: D:\New Folder\Products\rm-72\rm72_73_110M_03.80o Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 003500EC <=> SAMSUNG (SEC) -> K5E5657ACB Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_oncsm.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5648; Loader chk: 3 Loader is ready... Operation took 0 minutes 17 seconds... Erasing PPM... Mass Memory Device Detected... MM Bus Configured... Error MM Open! what is the problem gyes and what can i do now plez tell me and thanks advence.............. |
The Following User Says Thank You to Jakir Hussain For This Useful Post: |
06-28-2009, 17:50 | #3 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: BANGLADESH
Member: 852543 Status: Offline Thanks Meter: 2,338 | Quote:
The Following 2 Users Say Thank You to masum_sohel For This Useful Post: |
06-28-2009, 18:09 | #4 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 594019 Status: Offline Thanks Meter: 46 | I think the problem is in the selection of flash files MCU Flash file: D:\New Folder\Products\rm-72\rm72_73_11003.800 PPM Flash file: D:\New Folder\Products\rm-72\rm72_73_110M_03.80o CNT Flash file: D:\New Folder\Products\rm-72\rm72_73_110E_03.80.ucp_mobistar_be3 you have chosen 110M in PPM and 110E in CNT, it must be same in both: if not solved with "E" choose "M" Last edited by lucky_gsm; 06-28-2009 at 18:15. |
06-24-2010, 09:55 | #7 (permalink) |
Insane Poster Join Date: Nov 2005
Member: 202469 Status: Offline Thanks Meter: 7 | JAF version 1.98.62 Detected PKEY: 90009F72 Card life counter: 99.99% P-key nokia module version 01.02 Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.23.0 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-12\ Scanning for ini files... INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.500 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50A CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_A ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50A CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_A ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50i PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50A CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_A ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic MCU: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50i Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x84A0; Loader chk: 38 Loader is ready... P-key nokia module version 01.02 MSID: 847CCDD292222DC969BE331C3A MSID decoded: 3E4EBAE900D11865AA000000 FAID: 8528B12AE86CE0D2C6BEA6A7 Operation took 0 minutes 19 seconds... Erasing... Found 1 interval(s) to erase Erasing area: 00940000 - 00B3FFFF... Operation took 0 minutes 20 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 6 seconds... Restarting MCU... NAND Format FAILED!!! CNT: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_A Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x84A0; Loader chk: 38 Loader is ready... P-key nokia module version 01.02 MSID: 847CCDD292222DC969BE331C3A MSID decoded: 3E4EBAE900D11865AA000000 FAID: 8528B12AE86CE0D2C6BEA6A7 Operation took 0 minutes 19 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 00940000 - 00B3FFFF... Operation took 0 minutes 20 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 8 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Extracting Content Pack... Error setting local mode... CP Extract Failed! PPM: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50A Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x84A0; Loader chk: 38 Loader is ready... P-key nokia module version 01.02 MSID: 844408CD99D168CA3FF4DC2410 MSID decoded: 3E4EBAE900D11865A9000000 FAID: 41A75BA93A117422284FD0D6 Operation took 0 minutes 18 seconds... Erasing PPM... Found 1 interval(s) to erase Erasing area: 00940000 - 00B3FFFF... Operation took 0 minutes 20 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 9 seconds... Restarting MCU... Flashing Done! Operation took 3 minutes 28 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50i PPM Flash file: NONE CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_A ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50i PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\ora_il.pro2 CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_A ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50i PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\ora_il.pro2 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50i PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\ora_il.pro2 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE MCU: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50i Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x84A0; Loader chk: 38 Loader is ready... P-key nokia module version 01.02 MSID: 847CCDD292222DC969BE331C3A MSID decoded: 3E4EBAE900D11865AA000000 FAID: 8528B12AE86CE0D2C6BEA6A7 Operation took 0 minutes 19 seconds... Erasing... Found 1 interval(s) to erase Erasing area: 00940000 - 00B3FFFF... Operation took 0 minutes 20 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 6 seconds... Restarting MCU... NAND Format FAILED!!! PPM: C:\Program Files\Nokia\Phoenix\Products\rh-12\ora_il.pro2 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\ora_il.pro2 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50.ucp_m1 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50.ucp_m1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_mig_01.ws2 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50.ucp_m1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_mig_01.ws2 CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50.ucp_i_MSN ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE MCU: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50.ucp_m1 Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x84A0; Loader chk: 38 Loader is ready... P-key nokia module version 01.02 MSID: 847CCDD292222DC969BE331C3A MSID decoded: 3E4EBAE900D11865AA000000 FAID: 8528B12AE86CE0D2C6BEA6A7 Operation took 0 minutes 19 seconds... Erasing... Found 1 interval(s) to erase Erasing area: 00940000 - 00B3FFFF... Operation took 0 minutes 20 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 11 seconds... Restarting MCU... NAND Format FAILED!!! CNT: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50.ucp_i_MSN Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x84A0; Loader chk: 38 Loader is ready... P-key nokia module version 01.02 MSID: 847CCDD292222DC969BE331C3A MSID decoded: 3E4EBAE900D11865AA000000 FAID: 8528B12AE86CE0D2C6BEA6A7 Operation took 0 minutes 19 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 00940000 - 00B3FFFF... Operation took 0 minutes 20 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 9 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Extracting Content Pack... Error setting local mode... CP Extract Failed! PPM: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_mig_01.ws2 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_mig_01.ws2 CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50.ucp_i_MSN ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50.ucp_i_MSN ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50e PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50e PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50.ucp_m1 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50e PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11005.50.ucp_m1 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.500 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50O CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_ORA_UK ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,Italian,Spanish,Turkish MCU: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.500 Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x84A0; Loader chk: 38 Loader is ready... P-key nokia module version 01.02 MSID: 84EF6C4BC351D55330E1AFCD1C MSID decoded: B03FBAE900D11865A9000000 FAID: 9BEF9B20E71BBB87DEEC5495 Operation took 0 minutes 19 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 007FFFFF... Erasing area: 00800000 - 0093FFFF... Erasing area: 00B60000 - 00FEFFFF... Operation took 2 minutes 18 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 49 seconds... Restarting MCU... NAND Format OK! CNT: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50.ucp_ORA_UK Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x84A0; Loader chk: 38 Loader is ready... P-key nokia module version 01.02 MSID: 844408CD99D168CA3FF4DC2410 MSID decoded: 3E4EBAE900D11865A9000000 FAID: 41A75BA93A117422284FD0D6 Operation took 0 minutes 26 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 00940000 - 00B3FFFF... Operation took 0 minutes 19 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 9 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Extracting Content Pack... Running: (c) Nokia File Server CP Extract Failed! PPM: C:\Program Files\Nokia\Phoenix\Products\RH-12\rh12_28_11005.50O Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x84A0; Loader chk: 38 Loader is ready... P-key nokia module version 01.02 MSID: 844408CD99D168CA3FF4DC2410 MSID decoded: 3E4EBAE900D11865A9000000 FAID: 41A75BA93A117422284FD0D6 Operation took 0 minutes 19 seconds... Erasing PPM... Found 1 interval(s) to erase Erasing area: 00940000 - 00B3FFFF... Operation took 0 minutes 20 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 9 seconds... Restarting MCU... Flashing Done! Operation took 5 minutes 51 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-12, Software version: 05.50 IMEI: 355038007491963 Product Code: 0513072 Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 6 seconds... Done! Done! Done! |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
6230 524 flash problem | patric | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 02-07-2005 03:45 |
6230 flashing problem!!!bug in griffin box | stanl_c | Griffin | 5 | 04-25-2004 15:15 |
6230 & 3660 flashing problems | haluka | Griffin | 3 | 03-28-2004 14:18 |
