Old 05-19-2006, 09:33   #1 (permalink)
Member: 135019
6230 key Up menu doesnt work
Hi,
I've changed the key Pcb and check the pin soldering. If problem is from Z301, normaly is serie of keys wich dont work, not only one.
Thanks for your help
Old 05-19-2006, 10:13   #2 (permalink)
gsmrepair1's Avatar
Member: 66871
Thanks Meter: 34
can you z300 change...
Old 05-19-2006, 11:13   #3 (permalink)
Member: 135019
thanks gsmrepair1
You think that Z300 fault can give one key fault? If sure i try to change it, but before if there is other posible faults..
Old 06-27-2006, 17:56   #4 (permalink)
thecult's Avatar
Member: 9700
Thanks Meter: 62
@bleck: problem is on Z301 , it's possible to get only one key faulty because each line drives each key... I have seen just this case (one key) in water damaged 6230 and problem was Z301
check this if you want to know what to change depending each keypad fail types:
http://forum.gsmhosting.com/vbb/show...02#post1840002
wbr
thecult
Old 06-28-2006, 07:13   #5 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
try this may help you
http://forum.gsmhosting.com/vbb/atta...2&d=1148110946
6230 volume up key not working please help asif_ae Nokia Hardware & Hardware Repair 3 11-22-2008 04:03
D500 keys up down soft 2 kamera key volume up not working remik140563 Samsung Hardware Repair 0 12-07-2006 14:08
6230 Keys 1,2,3 + DOWN menu not working platy Nokia Hardware & Hardware Repair 16 10-30-2006 23:00
6230 directional keys and menu button now working Burnt Cobba Nokia Hardware & Hardware Repair 4 08-26-2005 11:20
3510i keys doesnt work solution, udhai_12 Nokia Digital Core Technology 4 ( DCT-4 ) 6 12-02-2004 07:51
Page generated in 0.16915 seconds with 9 queries
