02-26-2005, 16:44 | #1 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Cyprus Age: 42
Member: 15149 Status: Offline Thanks Meter: 61 | 6230 network problem no access Best Regards Ps.It look lake bad Pa but it is ok |
02-27-2005, 14:01 | #4 (permalink) |
Member: 15149 Status: Offline Thanks Meter: 61 | When i power on i have a network about 5 second then nothing netowrk gone after few second i have select operator i find all netowrk operator and take one.I have now network but somethimes i have problem to call what i should do.I change PA,switch,helga,26mHz and the same.... help need |
02-27-2005, 14:25 | #5 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | Quote:
try to read PM values.if RF section is empty then write good PM values.also check if you have solder correct the PA. | |
03-06-2005, 22:27 | #8 (permalink) |
Freak Poster Join Date: Mar 2002 Location: near you Age: 44
Member: 10528 Status: Offline Thanks Meter: 4 | fix the doblex if it work good you must fix the breadg result (it have 6 pin and near pfo) if all that good and have same problem ................. change pfo and all will be ok. |
07-17-2007, 23:25 | #10 (permalink) |
Freak Poster Join Date: May 2006 Location: mumbai..9892136479
Member: 275451 Status: Offline Thanks Meter: 84 | plz chk this and then do something http://www.9916web.net/ NOKIA » ALL NETWORK & OTHER PROBLEMS SOLVED IN 48 HRS |
3530 :No network, Manual Search->Select Network -> No Access | arif_tual | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 11-11-2009 14:14 |
No Network & No Access what's the difference ?! | Laser | Old Ericsson Phones & Sony Phones | 1 | 06-09-2003 01:00 |
t28world connect network but no access | minhthanh | Old Ericsson Phones & Sony Phones | 1 | 10-24-2001 16:48 |
T28 have network but no access | ado | Hardware Equipments for GSM | 3 | 07-04-2001 09:42 |
T28 have network but no access | ado | Hardware Equipments for GSM | 0 | 07-02-2001 19:21 |
