04-09-2005, 12:04 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Bulgaria Age: 48
Member: 32284 Status: Offline Thanks Meter: 4 | 6230 no network solution needed... Here is the story....customer gave it to me with no network problem..phone see network for abot 15 sec...than network goes down...BTW..no transmiting..only network bars..well I decided to try the easy way...PM file flashed...than phone goes restricted /strange/...tryed to unlock..comunication failed in griffin...than I full flashed it..than unlock...after this..no network bars..no transmiting...ok...than I opened it...it was clear to see that some one has heated PA...now..what is in my mind...dameged PA..but phone see network with helga chip...I reheated helga..no result... Now...any idea will be apreciated... Thanks and regards! sergo_zmeia |
04-09-2005, 13:22 | #2 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: www.sevgigsm.net Erkan Yasar Age: 61
Member: 81576 Status: Offline Thanks Meter: 2,128 | Quote:
big helper http://forum.gsmhosting.com/vbb/show...&postcount=235 ccont+cobba=helgo | |
The Following User Says Thank You to sevgigsm For This Useful Post: |
04-12-2005, 09:37 | #4 (permalink) |
Member: 32284 Status: Offline Thanks Meter: 4 | Hi! Im getting mad...realy need help with this phone..I was that brave and stupid..to change PA...after that phone doesnt power up..I removed PA...same..can flash it ok...but no power up...consumption aroud 50mA.. any idea how to light it up again... Thanks and regards! sergo_zmeia |
04-15-2005, 13:07 | #5 (permalink) |
Member: 32284 Status: Offline Thanks Meter: 4 | Hi! Any body??? some more info..with griffin I can flash but, after flash processing cant be done...only with UFS I can full flash it..but no power yet...any ideas please.. Thanks and regards! sergo_zmeia |
04-17-2005, 02:25 | #7 (permalink) | |
04-17-2005, 08:57 | #8 (permalink) |
No Life Poster Join Date: Jan 2002 Location: MARS
Member: 8304 Status: Offline Thanks Meter: 362 | I have one with similar problems but my P.A is faulty.Whenever i take one from other board it makes dead short on board and phone cant power on.I think we can only use new P.A on these phones. |
05-01-2005, 07:22 | #10 (permalink) |
Freak Poster Join Date: Dec 2000 Location: Croatia
Member: 2765 Status: Offline Thanks Meter: 12 | I had the same problem, so first clean and remove old solder from the board, than flux the PA and pay attention to have clean and no shorted pads of PA. Than rehot the board, place the PA, and hot foc cca 20sec. at 330 degrees. Must power on. Without PA the phone can't power on. Aslo check the power ON switch. Can be overheated, so you have to chane it. WBR dghersin |
6230 No network coverage problem! | Tom_x | Nokia Hardware & Hardware Repair | 10 | 06-14-2009 06:28 |
j210 NO NETWORK SOLUTION NEEDED | khalidsain | Sony Ericsson Hardware Repair | 0 | 08-14-2007 10:22 |
i need t630 real no network solution | GOODNESS | Sony Ericsson Hardware Repair | 0 | 11-30-2006 20:17 |
6230 No Network After Full Flash! | Maurone | Twisterflasher | 23 | 05-26-2005 12:07 |
