11-14-2005, 13:36 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: POLAND
Member: 27761 Status: Offline Thanks Meter: 55 | 6230 only blinking i have nokia 6230 it's only blinking first lcd blink (when batery is connected) is white lcd then next blinks are only grey(dark) it's communicate with griffin, flashing mcu OK, format failed, flashin PPM ok Afer flash failed, no local, test mode etc. phone don't power on what should i check ? i try only flashing and rehot pcb only. |
The Following User Says Thank You to PSG For This Useful Post: |
11-14-2005, 14:10 | #3 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 55 | why i heve to erase eeprom? there is no any interesting parameters for powering up anyway i don't have right PM file and erase file. anybody have backup ? Last edited by PSG; 11-14-2005 at 14:22. |
11-21-2005, 06:26 | #6 (permalink) |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | Hi FULL ERASE FLASH WITH LATEST VER. FROM UFS..... DIRECTLY INT;S SIM LOCK'S AND FORMAT USER AREA IF YOUR PROBLAM SOLVE TRY TO DO ALL UI SETTING AN FORMAT USER AREA AGAIN.... IF NOT THEN TRY TO FORMAT PHONE FOR MORE THEN 10 TIME'S PROBLAM WILL BE SOLVE 100%...... WBR MUNNA WWW.GSMMUNNA.COM |
11-24-2005, 21:21 | #7 (permalink) |
Freak Poster Join Date: May 2003 Location: BG
Member: 29861 Status: Offline Thanks Meter: 5 | javajohn, how do u write a "good pm" on a dead phone?!? psg try hardware. resoder flash, RAM, leave the NAND alone... after that try full erase and writing pm etc... |
03-10-2006, 02:38 | #8 (permalink) |
Insane Poster Join Date: Nov 2005
Member: 201127 Status: Offline Thanks Meter: 7 | i bought a 6230 with this fault today. i just reflowed the ram and uem on medium heat - works perfect now. probably just loose / dry joints. if reflow doesnt work - replace ram, if ram replaced and still no power - replace uem. hope this helps! post results please! |
07-05-2008, 05:07 | #9 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | 6230 lcd blinking Quote:
MOTO V3i ONLY BLINK ONE TIME SOW ONLY MOTOROLLA | madeena | Motorola P2k | 0 | 05-03-2008 17:42 |
6230 lcd blink only | samadgsm | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 12-07-2006 08:02 |
6230 just blinking and no power! | GSM WIZARD | Nokia Hardware & Hardware Repair | 6 | 03-10-2006 02:34 |
6230 only blinking light after PBB | gsm_unlock | Phoenix Black Box | 1 | 07-14-2005 18:12 |
E720 only blink blink | ianek | SYSOL Platform | 2 | 07-11-2005 17:19 |
