10-15-2007, 08:30 | #1 (permalink) |
Junior Member Join Date: Apr 2006
Member: 266631 Status: Offline Thanks Meter: 0 | 6230 power on |
10-15-2007, 13:36 | #3 (permalink) |
Member: 266631 Status: Offline Thanks Meter: 0 | I replaced power switch, but still same problem. I also forgot to write that when wont power up, lcd blink (on~3 second/off~1 second). Do You know what else might be problem? Thanks. |
10-16-2007, 03:54 | #5 (permalink) |
Insane Poster Join Date: Mar 2007 Location: Egypt Age: 40
Member: 473823 Status: Offline Thanks Meter: 10 | u should see its results at Software then u will decide where the probem will be and i want to add if it charge normally when u put the charger it will be from the on/off button or the battery connector |
6230 power on/off pb solved | mazentel.. | Nokia Hardware & Hardware Repair | 7 | 06-17-2008 07:33 |
nokia 6230 power on problem | nomi | Nokia Hardware & Hardware Repair | 0 | 11-27-2006 16:40 |
nokia 6230 power on problem | nomi | Nokia Hardware & Hardware Repair | 2 | 08-23-2006 19:00 |
nokia 6230 power on problem | screw8 | Nokia Hardware & Hardware Repair | 7 | 07-13-2006 09:30 |
6230 Power On | ahmedksal | Griffin | 1 | 10-14-2004 10:42 |
