Old 04-13-2005, 19:53   #1 (permalink)
Member: 3691
Thanks Meter: 6
6230 power off
Hi...
I have some problem with nokia 6230 when sim card inside after 50-60sec phone is power off. Any experiance with this problem.
I try read info with ufs 3 all is OK. Only product code mised.
Thanks,
Old 04-13-2005, 19:56   #2 (permalink)
Member: 22101
Thanks Meter: 16
hi,
just try first to PM by ufs3, or if not u must need to change the upp/cpu...
i have that problem before but i can make it 100%.
good lock and have agud tym.......
Old 04-13-2005, 20:01   #3 (permalink)
pes
Member: 65593
Thanks Meter: 17
I think the problem is not softwere.maybe hardwere solution for hoting to try.
Old 04-13-2005, 20:13   #4 (permalink)
gsmlab4u's Avatar
Member: 86003
Thanks Meter: 5
hi gosev i wil tel u this kind problem 50% sw and 50% hardware. wht u do first u
erase after u take 3.17 ver which 1 u put mcu the same file u select ppm. After
fullflash u unlock the phone at thesame time. proceeding finsh u select muc and
ppm and cont then full flash after unlock. i thin u got it.
gsmlab4u
Old 04-13-2005, 21:32   #5 (permalink)
needi's Avatar
Member: 18303
Thanks Meter: 3
Need to check SW then if problem persists measure system clock peak to peak.If necessary change oscillators.
Old 04-14-2005, 19:02   #6 (permalink)
Member: 3691
Thanks Meter: 6
Thanks, I solved problem after change upp now phone good work.
best regards,
Old 04-14-2005, 19:28   #7 (permalink)
Member: 107030
hi
you can sw witheout BT
Old 04-24-2005, 17:09   #8 (permalink)
Muneer Ahmed's Avatar
Member: 60500
Thanks Meter: 2
the problem can also b solved by ful factory reset & by formating user area
Old 04-24-2005, 17:59   #9 (permalink)
sunnyc's Avatar
Member: 49495
Sonork: 100.9 & 100.12345
Thanks Meter: 1,026
Broo y u worng post this is problam only hardware not software
6230 power on/off pb solved mazentel.. Nokia Hardware & Hardware Repair 7 06-17-2008 07:33
6230 Power Off.. LoveLess Nokia Hardware & Hardware Repair 6 03-24-2008 20:35
6230 power switch resistor ripped off pcb!? eddierasta Nokia Digital Core Technology 4 ( DCT-4 ) 0 09-07-2006 11:36
my 6230 powers off after 2 min after flash ionutz808 Nokia Digital Core Technology 4 ( DCT-4 ) 0 08-04-2005 12:45
Ericsson t65 allways power on - power off after 1 second- on - off - on - off oleg192 Sony Ericsson Hardware Repair 5 06-24-2003 16:38
Page generated in 0.18589 seconds with 9 queries
