Old 08-11-2006, 18:10   #1 (permalink)
kaiserstumm's Avatar
Member: 100770
Thanks Meter: 57
6230 Problem!
i have 6230 which was dead, i tryed to flash it but it stoped always at extracting contet!! Then i took the display off and flashing was fine without display!! Wit display back on the phone it worked few days well, now i cant turn it on again!! It seems to get turned on but befor the lights come on, it stops! Any ideas! Thank you!!
Old 08-12-2006, 05:44   #2 (permalink)
shakeelajmal's Avatar
Member: 51639
Thanks Meter: 76
i have 6230 which trun on after some time for few mins then automatically trun off.. the phone is dead not able to flash .
and when the phone on its working perfect.. any idea?
Old 08-12-2006, 12:39   #3 (permalink)
ozh
Member: 249060
Thanks Meter: 2
6230
hi try formatting A n C DRIVE on jaf then do sw if not work do erase try again if still fails do full erase an try higer n lower sw versin shhould wrk done plenty of those good luck
Old 08-12-2006, 13:09   #4 (permalink)
Member: 100770
Thanks Meter: 57
Can someone explain why it can be flashed witout display and with display not!?
Old 11-07-2007, 14:22   #5 (permalink)
Member: 589633
Thanks Meter: 6
6230 white light
i have a problem in 6230white displaychange display &ic please help meincoming and out going ok
Old 11-07-2007, 14:28   #6 (permalink)
Member: 589633
Thanks Meter: 6
shorting of vcore ic in 2112
Old 11-07-2007, 14:36   #7 (permalink)
Member: 562583
Thanks Meter: 4
i have the problem 6230 it's slow booting and 2 or 3minits phone is nomal on but blutooth not on and when camara is on disply the error memory is full deleat some data . iam flash the phone ple give the some solution
Old 11-07-2007, 15:59   #8 (permalink)
Member: 626297
signal problem slousion
Old 01-26-2008, 12:45   #9 (permalink)
Member: 477436
Thanks Meter: 3
hello sir i have 6230 with wite display but phone is complete i can here the nokia soun i cange lcd but its same and lcd is also ok
Nokia 6230 Problems!!! BadUnlockers Twisterflasher 4 10-23-2005 19:09
griffin 2.086 and 6230 problem ahmed Griffin 1 09-15-2004 17:40
RH-12 6230 Problem isaackenny Griffin 9 08-23-2004 11:00
6220 and 6230 problem ARC Nokia Digital Core Technology 4 ( DCT-4 ) 2 07-10-2004 17:08
Page generated in 0.22543 seconds with 9 queries
